Hey can anybody give me some kind of technical write up on "how to install the 180SX taillight kit on a 93 240SX for Dummies". I would greatly appreciate it.
Quick write up.
Remove the old lights, nuts are behide the carpet panel. 10mm is the size. Take them all off, and your under panel. Then install the underpanel first, then middle panel, then the lights. Make sure to use the black sealent they give you. Now, all you have to do is wire it up. You're going to have to cut the wires and connect them to the wires on the lights. OR ! ! You can give clearcorners.com a holla and ask for the speical plugNPlay harness. (Edited by Kid Zelda at 7:59 pm on Dec. 30, 2001) (Edited by Kid Zelda at 8<img src="#/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>1 pm on Dec. 30, 2001) |
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from Kid Zelda on 7:53 pm on Dec. 30, 2001
Quick write up. Remove the old lights, nuts are behide the carpet panel. 10mm is the size. Take them all off, and your under panel. Then install the underpanel first, then middle panel, then the lights. Make sure to use the black sealent they give you. Now, all you have to do it wire it up. You're going to have to cut the wires and connect them to the wires on the lights. OR ! ! You can give clearcorners.com a holla and ask for the speical plugNPlay harness. (Edited by Kid Zelda at 7:59 pm on Dec. 30, 2001) </td></tr></table><span id='postcolor'> |
Already swapped my 180sx lights but I was curious....
<<You can give clearcorners.com a holla and ask for the speical plugNPlay harness.>> How do those work? Does it plug into the USDM harness, and then have another fitment for the JDM? |
