![]() Join Date: Jan 2009
FS: N62, S13, S14, KA Parts
I need to fix my engine, therefore I need money. The easiest way to get money is to sell stuff, so here is my for sale ad.
A18-B92-GOO - '95 s14 Manual Transmission OBDII ECU - $40 SOLD A11-B45-G71 - '93 s13 Automatic Transmission ECU. Remove your speed limiter, drive faster. If you're getting an ECU tune they can change the ECU from auto to manual, you can use it as a core when sending out an ECU, or you can run it while your ECU is getting tuned. - $40 "Crystal" clear chuki turn signal lenses. They plug into your stock harness and come with the mounting screws. - $20 Tie rod rubber boot thing. Comes with zip ties to secure it to the rack and inner tie rod- $10 SOLD Garrett/Nissan 5 bolt turbine outlet flange. Helpful if you're making your own downpipe. - $20 KA24DET Turbo Manifold. Bottom mount SSA t2 flanged manifold, it's been used and abused. It doesn't have any cracks, one of the runners is hammered in slightly though...don't ask. Comes with t2 gasket. - $40 SOLD 370cc injectors. They're stock SR injectors, I used them in my KA until I upgraded. They're great for a stock mafs/t2 turbo setup, they can handle around 250whp, so a t25 at around 10psi. - $80 Z32 N62 MAFS. Commonly used when upgrading injector size. Comes with pigtail. - $60 SOLD All prices are OBO, and I'm down for combined item discounts. Let me know what you want and I'll see what I can do. Contact me by responding to this thread, sending me a private message, or call/text me at 757-788-9847. I'm located in Raleigh, I'll ship but it will be at buyer's expense. Thanks for your interest. Last edited by Chris28; 09-27-2011 at 09:56 AM.. |
