![]() Join Date: May 2008
Trader Rating: (41)
![]() Feedback Score: 41 reviews
S14 KA24de 5-speed transmission complete/flywheel/clutch assy
I am selling my S14 KA24de 5-speed transmission I no longer need. I was keeping it as a spare but, just need to clear up some space in the storage now. The transmission had roughly 155,000 miles when pulled. The transmission shifted smooth in every gear with no grinds or pop outs.
The transmission comes complete with the following: - Fork - Throw out bearing assembly - Sensors - CPS on bell housing - Slave cylinder - Clutch and pressure plate assembly - Flywheel - Shifter housing with shifter - Hardware for flywheel and clutch There are some small issues that I will address - The drain plug is stripped (the previous owner stripped the exterior of the plug not the threads. The plug does not leak. I am sure with some finesse the plug can be replaced. - Flywheel requires a resurface - Fork is missing the rubber dust boot - Shifter housing 6 bolt gasket is torn I am trying to keep this as a complete set for now. I am asking 250.00 picked up in Yuma, AZ I plan on leaving from Yuma and heading to LA on Saturday. So if anyone is interested in the SoCal area I might be able to take it and do a meet up. PM me if interested. |
