Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Suspension
Old 11-14-2011, 06:07 PM   #1
Fatboy Garage
Fatboy Garage's Avatar
Fatboy Garage is an unknown quantity at this point
Send a message via MSN to Fatboy Garage
Talking Godspeed Project S13 S14 Steering Angle Adaptor
These are going for: $35 picked up or $40 Shipped (California customers please add 9.25% to shipped price for shipping cost.)
Now in stock is the S13 / S14 Steering Angle Adapter.
Comes with: (1) Steering Angle Adapter & (1) 7mm spacer (Optional for bit more angle)
Below is the specifications when used with the spacer:
GODSPEED steering angle adaptor will allow your steering angle from 38 degree (oem) to 52 degree (gsp adaptor). That is a total of 14 degree gain over stock.
Simply install the adapter on the passenger side of the steering rack and re-center the rack after install. That's it! (See pictures below for example)
OEM vs. Godspeed Project
Leading wheel: OEM is 38 degrees vs. Godspeed is 52 degrees
Trailing wheel:
OEM is 30 degrees vs. Godspeed is 39 degrees
Turning circle (curb-to-curb):
OEM is 30 feet vs. Godspeed is 24 feet
Lock-to-Lock:
OEM is 3 turns vs. Godspeed is 2.8 turns
Angle after adapter installed:
Godspeed Project
2518 Continental Ave
El Monte CA 91733
P: 626-442-3988
W:godspeedproject.com
www.facebook.com/godspeedproject
Fatboy Garage is offline   Reply With Quote
Old 11-15-2011, 11:21 AM   #2
Chaluska
Chaluska is an unknown quantity at this point
how does the lock to lock decrease when lengthening the steering rack? i think you have a typo there..
but this is pretty cool, do you have to remove the bump stops on the control arms?
Chaluska is offline   Reply With Quote
Old 11-15-2011, 11:35 AM   #3
TheRealSy90
TheRealSy90's Avatar
It decreases lock to lock because you basically hit the bump stops faster when you increase the steering angle this way.
If you remove the bump stops i'm sure you would just get that much more steering angle.
Such a good signature.
Old 11-15-2011, 01:05 PM   #4
Fatboy Garage
still have these in stock!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 11-16-2011, 07:49 AM   #5
Chaluska
.. really now...
the gear ratio never changes in the steering rack, so if the lock to lock is defined ONLY by the bump stops on the control arms, then it wouldn't matter if you put a 15" spacer on the rack, the rack cant push beyond the bump stops.
my main question was do the bumpstops have to be removed, and i think the answer is yes.
Old 11-16-2011, 12:16 PM   #6
Fatboy Garage
Originally Posted by Chaluska View Post
.. really now...
No, the steering stops do not HAVE to be removed. Its not necessary, you can grind down them down to get even more of an angle.
But these adapters can be installed without having to grind down the steering stops.
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 11-16-2011, 03:39 PM   #7
TheRealSy90
.. really now...
Well if you lengthen the rack, putting the ends further out, thus less distance they have to travel before hitting the bumpstops, less "turns to lock"?
Old 11-17-2011, 02:49 PM   #8
Fatboy Garage
Still have these in stock.
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 11-18-2011, 01:11 PM   #9
Fatboy Garage
Still available!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 11-21-2011, 11:34 AM   #10
Fatboy Garage
Still have these in stock!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 11-23-2011, 11:48 AM   #11
Fatboy Garage
These are still available!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 11-24-2011, 04:38 PM   #12
EvoVIII808
Got Mine, Thanks. will get some pics posted Install time was 45min total with alignment and rack re-center.
Check Out My S13 Build
Old 11-24-2011, 04:53 PM   #13
poneyrunner
poneyrunner is an unknown quantity at this point
im curious. if you bought one for each side would it make both wheels have 52 degrees of steering angle? why do you only get one? and wouldnt only having one mess up your tire wear when turning?
poneyrunner is offline   Reply With Quote
Old 11-25-2011, 01:12 AM   #14
EvoVIII808
no, you would actually have more than 52 degrees of angle (66 to be exact). but you would overcenter, or hit something before you could use all the angle it would give you. Would also need inner and outer rod/ rod ends.
You only get 1 because you Re-Center the rack after you install it, and you have to get you Toe angle re-aligned.
Old 11-25-2011, 07:28 AM   #15
poneyrunner
well i have tien inner and outer rods and stock lca. so if i got 2 of these wouldnt it hit the bump stops but give me max angle for both wheels? i just dont really understand how it can be god to have more angle on your leading tire than your trailing tire. seems to me that it would cause alot of wear on the trailing tire as well as mess with your drifting fluidity. so if i got adapters for both sides would it allow me more angle for both sides keeping them the same?
Old 11-25-2011, 01:17 PM   #16
EvoVIII808
You will get the same steering angle from both sides with 1 if you re-center you rack properly. if you install 2, you get 28 degree of steering angle capability, and wont have to re-center your rack, but you will be over centering the wheels without other mods.
Do some research in the roll center thread. A-lot of your questions will be answered there.
Old 11-25-2011, 01:46 PM   #17
poneyrunner
i attempted to read and understand the whole suspension thread that was about setting up a car for drifting and couldnt understand any of it.. i tried reading the threads they sent you to to help understand it and it got all mumble together and got confusing to me.. ill try to look it up again..
Old 11-25-2011, 06:51 PM   #18
EvoVIII808
Haha, well you might want to start small, and work your way up
Just order 1 adaptor, recenter your rack, and enjoy the extra angle. If you need more, you will have to get some Steering Knuckles, and notch or buy some new FLCA (front Lower Control Arms) so your tie rod ends dont hit.
I think God Speed has everything you need for suspension.
Old 11-25-2011, 10:39 PM   #19
poneyrunner
haha.. ok thanks... do you think you could simplify the roll center stuff? i think i understand the concept behind it. its a ratio based between your center of gravity and where you knuckles are? and having your roll center at the same level or a bit higher you get less body roll and more steering angle? am i right about this?
Old 11-28-2011, 07:38 PM   #20
Fatboy Garage
50% off sale going on today, last day.
#/f/advertiser-announcements-feedback/420917-godspeed-project-black-friday-special-50-off-msrp.html
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 11-29-2011, 11:38 AM   #21
Fatboy Garage
Still have these angle spacers in stock!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 11-30-2011, 11:46 AM   #22
Fatboy Garage
Still have these angle spacers available!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 11-30-2011, 11:47 AM   #23
EvoVIII808
Got mine installed.. Thanks guys =)
Old 11-30-2011, 11:59 AM   #24
Fatboy Garage
NICE! You are very welcome.
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 12-01-2011, 10:58 AM   #25
Fatboy Garage
Bump still have a few of these left in stock!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 12-02-2011, 02:38 PM   #26
Fatboy Garage
Still have this in stock!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 12-05-2011, 04:48 PM   #27
Fatboy Garage
in stock ready to go!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 12-05-2011, 06:34 PM   #28
EvoVIII808
Took me from doing 3pt turn arounds to 1 single turn at full lock on a 2 lane street. good mod for the price! Thanks Again.
Old 12-06-2011, 11:02 AM   #29
Fatboy Garage
Still in stock!!!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 12-09-2011, 11:25 AM   #30
Fatboy Garage
Still have these available!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
