![]() Join Date: Sep 2008
which oil filter ?????
which oil filter goes on a s14 blacktop sr20det. i have been reading the threads that have been posted and everyone is confusing me the last time i bought the k n n hp1003 it didnt fit on my car?? please help me out i need to change my oil tommorow thank you......
#3 | |
![]() Join Date: Jun 2007
dude in this thread #/f/cars-sale/181032...y-8k-mods.html used a greddy one
taken from another forum Quote:
![]() Join Date: Nov 2007
you can use an oil filter from a 91 sentra ser or just order one from frsport.com, thenismoshop.com
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
you can use pretty much any Nissan filter, i prefer the filter that ends with Y000 because it's the biggest one, i've been using them on RB20's and RB26's but i believe the proper one is the one that ends with E000
#8 | |
Man w/ CTSV & a Car Seat
Negative on that one ghostrider...S13 SRs use the same filter from the older FWD SRs. 91-93 SE-R will work. For S14 engines tho, use the 95 and up SE-R. If you try to put a 95 filter on an S13, you'll have a nice lil "thump" and have about 3 qts of oil under your car. Trust me, I know... |
I use the OEM ones from thenismoshop on my S14 SR. Some people complain about the paper endcap, but I haven't had any problems so far after 3 oil changes.
97 240sx se |
![]() Join Date: Mar 2008
Trader Rating: (81)
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 81 reviews
the mobil 1 oil filter is M-101 right? for s13 SR?
http://squarespokes.com/ |
![]() Join Date: Apr 2005
nissan part # 15208 53J00 is s14 oem filter
Nissan OEM Oil Filter S14/S15 SR20DET oem > k&n, fram, duralast, etc |
#16 | |
#17 | |
meh, they might be close to the same. the picture makes it look kinda bigger though.
97 240sx se |
