Old 07-05-2021, 09:03 PM   #1
jdmmatt
jdmmatt is an unknown quantity at this point
Calipers smoking
just 5 lug swapped my s13 and now my front drivers/rear pass calipers are smoking and/or stuck
brand new pads/rotors/and calipers and properly bled. Brake pedal gets stiff after a couple minutes of driving and starts to smell and smoke. any ideas?
jdmmatt is offline   Reply With Quote
Old 07-06-2021, 05:05 AM   #2
dizzariot
dizzariot's Avatar
Trader Rating: (47)
Feedback Score: 47 reviews
This doesn't sound very 'jdm' of you, jdmmatt.
1.) It's Oregon so check the brakes for crack pipes.
2.) Check piston dust boots.
3.) Bleed brakes again.
Old 07-06-2021, 06:51 AM   #3
Kingtal0n
Kingtal0n's Avatar
could not resist
Maybe trash in the lines or behind pistons... rebuild the calipers if they are 20 or 30 years old ?
Assuming everything is squared up / properly installed. The rotors should spin easily with the calipers installed before you touch the brake pedal, the rotor should be nice and flat, no trash under it, and properly torqued under the wheel. A slight misalignment anywhere and...
Old 07-06-2021, 09:01 AM   #4
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
so. . . .
what calipers are you using now? s13? z32? CTSV?
where did the calipers come from? you said "brand new", so autozone? rockauto?
were the brakes functioning properly beforehand???
Old 07-06-2021, 01:11 PM   #5
spooled240
spooled240's Avatar
Pull the wheels off and unbolt the calipers. When you bolt them back on check if they are binding on anything and applying force on the rotors. You might have received the wrong rotors with an incorrect offset/rotor height.
JDM mat would know if there's something wrong with his buddy, JDM brake pedal.
Old 07-06-2021, 04:41 PM   #6
burnsauto
burnsauto's Avatar
burnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfection
Send a message via AIM to burnsauto
that took me way too long to get that...
burnsauto is offline   Reply With Quote
Old 07-06-2021, 05:29 PM   #7
jdmmatt
s14 5 lug rotors from oreiliys. and yes brakes were perfect before.
so. . . .
Old 07-06-2021, 07:36 PM   #8
bigs
S14 rotors are thicker than S13. If you're still running S13 calipers that might be the issue.
I think there's a difference between abs and non abs thickness as well.
Been a while since I dealt with this, so someone needs to fact check me. I remember running into the same problem, and I just had to get the correct rotors.
Old 07-07-2021, 06:37 AM   #9
SupaDoopa
SupaDoopa's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
There is a very obvious explanation as to what you did especia-...
Let me know when you pull it apart at least two more times. I want proof, too.
Old 07-07-2021, 06:55 AM   #10
RB25GUY
RB25GUY's Avatar
stupid question did you clean the rotors with brake kleen?? but if they are s13 calipers you might need to use some sort of caliper spacer.
Old 07-10-2021, 04:05 PM   #11
cotbu
cotbu's Avatar
its really hard to diagnose this issue, not having a record of whats actually what? so if you try all the things mentioned, I'd look at the piston in the brake booster. it is an IIRC an 8mm nut that can be adjusted in very small increments. Or at least, if you have the time look it up to see if it could apply to your issue.
Old 07-10-2021, 05:15 PM   #12
NukeKS14
NukeKS14's Avatar
NukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really nice
... Brake pedal gets stiff after a couple minutes of driving and starts to smell and smoke. any ideas?
Did you do anything with your brake booster? Almost sounds like your check-valve is getting stuck. If you can recreate the problem, try disconnecting the vacuum line upstream of your check valve on the booster side. If the brakes release, you've found your problem.
NukeKS14 is offline   Reply With Quote
Old 07-16-2021, 03:20 PM   #13
mechanicalmoron
mechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nice
It may seat in each direction, but the check valve doesn't do what you think it does. It won't apply your brakes for you if you put it backwards.
Are the guide pins stiff with crud, or hydraulically/pneumatically locked on their grease?
mechanicalmoron is offline   Reply With Quote
