Old 01-10-2009, 11:11 AM   #1
aardvark
aardvark is an unknown quantity at this point
R33 GTR vs GTS brake calipers
how do i tell the difference between the r33 gtr calipers and the r33 gts calipers? correct me if i'm wrong, but the gtr uses a 324mm rotor, where the gts has a 300mm rotor.
aardvark is offline   Reply With Quote
Old 01-10-2009, 11:15 AM   #2
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
The R33 GTR came standard with brembo's didn't they?
racepar1 is offline   Reply With Quote
Old 01-10-2009, 11:23 AM   #3
renegade_ewok
renegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to behold
Yes.
My friend has GTS-T brakes on his 240 and they are indeed bigger than Z32 brakes (by a good bit, these things are beefy as fuck) but I don't know the rotor size comparison to the brembo setup on the GT-Rs. To be honest, a GTS-T setup stops on a fuckin' dime and any more will either pull your teeth out if you have slicks all around or you will just lock up with anything less. Hell, Z32 setup can lock up tires going 30 if you slam the brakes. There really isn't a need for a brembo setup, but hey if you got your hands on some go to it.
renegade_ewok is offline   Reply With Quote
Old 01-10-2009, 11:33 AM   #4
racer98
racer98's Avatar
Trader Rating: (128)
racer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant future
Feedback Score: 128 reviews
Send a message via AIM to racer98 Send a message via MSN to racer98
there are a couple of models to choose from
R33 GT base 4lug
R33 GT-S base + has a 4piston caliper
R33 GT-S T same as above
R33 GTS-T (Type-M) This is a large sumutomo caliper with a 310mm rotor
R33 GT-R base same as above but never seen one like this
R33 GT-R Vspec - Brembo
but I might be wrong.
racer98 is offline   Reply With Quote
Old 01-10-2009, 11:37 AM   #5
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
R32 GTR used similar calipers to the ones that come on the R33 GTST. though the 32GTR came with a 32mm rotor and the 33 GTST had a 30 milmeter. The piston sizes were the same though.
R32GTR V spec used a Brembo as well as far as I know R33 GTR came with Brembo's
These are Fronts I am talking about not rears.
New Video
Buy my mounts!
Old 01-10-2009, 12:24 PM   #6
Katsumbhong
Katsumbhong's Avatar
Katsumbhong is making a name for him/her selfKatsumbhong is making a name for him/her selfKatsumbhong is making a name for him/her self
R33 GT base 4lug
R32 GTR used the same caliper that comes on the R33 GTST. R32GTR V spec used a Brembo which wound up coming on R33 GTR's
All 2-piston rear brakes (Z32, R32 Turbo GTST, R33 GTS25t, etc) are the same (except for Brembos that come on the VSpec GTR's)
FRONT BRAKES
-R32 non turbo used 4-lug brakes that are similar to the S13/180sx and S14 Q's
-R32 Turbo GTS-T has 4-piston calipers (AFAIK the same as Z32, don't remember, if it's turbo or non turbo)
-R33 non turbo (4-lug) uses a twin piston floating caliper which is an upgrade for stock 180sx/S13 and S14 Q. The Rotor is exactly the same as the R32 GST-T except it is 4-lug
-R33 GTS25-t uses 5-lug brakes, the Rotors are larger than the R32 GTS-T and the caliper is still a 4-piston unit but is designed differently.
-R32 GTR Non-VSpec has larger rotors and calipers than the R32 and R33 turbo, and come with XDrilled and slotted rotors.
I'M GETTING ALL THIS INFORMATION first hand. I have worked, installed, collected, and sold many Nissan brakes while I was stationed in Okinawa.
R32 GTR Non-Vspec
R33 GTS25-t
Katsumbhong is offline   Reply With Quote
Old 01-10-2009, 12:49 PM   #7
Heatw
Heatw is on a distinguished road
r33 gts-t rotors are 296x30
r32 GTR rotors are 296x32
you could use r32 gtr rotors in a r33 caliper.. tho they aren't the same, they might as well be, uses the same pads etc.
Heatw is offline   Reply With Quote
Old 01-10-2009, 01:06 PM   #8
drift freaq
FRONT BRAKES
R32 GTR Non-Vspec
R33 GTS25-t
your are basically splitting hairs here. Fact is the The R32 GTR Caliper is the exact same physical piston size and as the R33 GTST. The Caliper may look slightly different but its going to use the same pads. Also as someone else stated above there is 2mm difference in rotor thickness. That is all.
I appreciate what your posting but please don't misconstrue what I was saying. I should have put I am talking about fronts not rear. Now if the R33 GTR did not come with Brembo fronts feel free to correct me. Though I am not talking about the rear calipers here.
I might add Nissan is known for sticking Brembo calipers on the front of some of their cars but not in the rear i.e. Sentra SER V spec.
New Video
Buy my mounts!
Old 01-10-2009, 02:01 PM   #9
lflkajfj12123
who cares about stopping
i just want r33 brembo's for the streeeet cred
Old 01-10-2009, 02:14 PM   #10
articdragon192
articdragon192's Avatar
FYI, Z32 calipers are different from the R-chassis. The mounting ears on the R-chassis calipers are bigger, pushing out the caliper allowing it to use a bigger rotor. However, pad size is the same.
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 01-10-2009, 02:26 PM   #11
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
heres a quick list
R32 T : 280mm x 26mm (single pot sumitomo caliper)
R32 GTS-T (early) : 280mm x 26mm (single pot sumitomo caliper)
R32 GTS-T type m : 280mm x 30mm (4 pot sumitomo caliper)
R32 GTR : 296mm x 32mm (4 pot sumitomo caliper)
R32 GTR VSPEC : 324mm x 30mm (4 pot brembo caliper)
R33 GTS-25 : 280mm x 26mm (single pot sumitomo caliper)
R33 GTS-4 : 280mm x 26mm (single pot sumitomo caliper)
R33 GTS-25T : 296mm x 30mm (4 pot sumitomo caliper)
R33 GTR : 324mm x 32mm (4 pot brembo caliper)
R33 GTR VSPEC : 324mm x 30mm (4 pot brembo caliper)
R34 GT : 296mm x 30mm (4 pot sumitomo caliper)
R34 GTT : 310mm x 30mm (4 pot sumitomo caliper)
R34 GTR : 324mm x 32mm (4 pot brembo caliper)
Z33 NA : 324mm x 32mm (4 pot brembo caliper)
Z32 NA : 280mm x 26mm (4 pot sumitomo caliper)
Z32 TT : 280mm x 30mm (4 pot ali sumitomo caliper)
S14, S15 : 280mm x 30mm (4 pot sumitomo caliper)
lexus baby
5t341tH is offline   Reply With Quote
Old 01-10-2009, 07:26 PM   #12
racer98
racer98's Avatar
Thanks for the post would you mind reading the post before you start calling me out on something else.
Old 01-10-2009, 07:29 PM   #13
racer98
racer98's Avatar
+1 when I read the anatomy of the 1st post you made it clear what you were talking about and I added what info I could share for you project.
let me know what else happens with the research your doing with the brakes.
Got myself a set of R35 GT-R brembo's F/R and working on ways to keep it in a 17in rim.
Old 01-10-2009, 07:30 PM   #14
racer98
racer98's Avatar
Originally Posted by 5t341tH View Post
heres a quick list
now that is some goood info !
Old 01-10-2009, 10:32 PM   #15
aardvark
FINALLY! been looking for that thorough list on the net forever, and a day.
Old 01-10-2009, 10:47 PM   #16
aardvark
thanks for the pics katsumbhong. i knew about the two different calipers but, i didnt know which models they were for, and if they used different size rotors. so its just a 2mm thickness difference huh. how available are these non-USDM rotors (ie 296mm, 310mm)?
Old 01-15-2009, 10:13 AM   #17
slider2828
slider2828's Avatar
Yah I wonder how available are these rotors
Turn and Burn!
Old 01-15-2009, 10:49 AM   #18
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
That is the TRUTH.
http://bhworld.wordpress.com/
Old 01-15-2009, 11:40 PM   #19
SRpetey
SRpetey is just really niceSRpetey is just really niceSRpetey is just really niceSRpetey is just really niceSRpetey is just really niceSRpetey is just really niceSRpetey is just really niceSRpetey is just really nice
www.dba.com.au has all rotor demensions in their catalog for any make and model and www.buybrakes.com has skyline rotors and I think its free shipping.
SRpetey is offline   Reply With Quote
Old 01-16-2009, 12:35 PM   #20
slider2828
slider2828's Avatar
Thanks I will remember that
Turn and Burn!
Old 02-04-2009, 04:32 PM   #21
Z33dori
Z33dori's Avatar
so has anyone found a cheaper place to find rotors for the gtst calipers.
i priced out some DBA slotted(cheapes ones from buybrakes.com) and they were 324 bucks....
is there no where to just get some oem rotors, or some similar sized oems rotors from another car.
Old 02-04-2009, 10:53 PM   #22
Mirage
Mirage is making a name for him/her selfMirage is making a name for him/her self
Send a message via AIM to Mirage
good luck with that, I got tired of looking and finally bought DBA's from buybrakes. Supposedly IS300 rotors are the same diameter but the caliper needs to have spacers/washers to make the offset fit. One of the socal nissan dealers had oem r32 gt-r rotors closed out awhile ago, drilled and blanks, for cheap, but they are 32mm vs 30mm, that and I found them after I had already got mine.
Mirage is offline   Reply With Quote
Old 02-04-2009, 11:22 PM   #23
Z33dori
Z33dori's Avatar
i just can't see myself spending that much on rotors.... specially since i only paid 170 for the calipers.
i'll prolly just buy some R32GTR rotors and shave them down, since i can do it myself for free. but it depends on the cost
Old 02-05-2009, 08:47 AM   #24
Mirage
Wouldn't it be easier to trade your calipers for some Z32 ones then if rotor replacement cost is an issue? You might be able to get a 32mm one in there, but mine were pretty tight with new pads on the 30mm's.
Old 02-05-2009, 11:29 AM   #25
Brian
Brian's Avatar
Trader Rating: (54)
for what it's worth.
I got brand new GTR32 rotors from Performance Nissan in Duarte.
The drilled ones even.
I bet they could help you out.
THe other option for me would be to go to
ENDLESS
or
Project Mu.
You are probably going to have to pay a lot, but at least they will be badass.
For some reason R32 GTR rotors (endless) are SUPER expensive.
Old 02-05-2009, 12:25 PM   #26
bblack_91240
bblack_91240's Avatar
bblack_91240 is just really nicebblack_91240 is just really nicebblack_91240 is just really nicebblack_91240 is just really nicebblack_91240 is just really nicebblack_91240 is just really nicebblack_91240 is just really nicebblack_91240 is just really nicebblack_91240 is just really nice
mynismo.com is the website. They're listed at $130/side for drilled and $95/side for plain. I'm thinking about picking up some R32 GTRs and doing that.
DD: '05 Saabaru with full JDM STi 6spd swap
Project: '91 S13 Hatch SR20
bblack_91240 is offline   Reply With Quote
Old 02-05-2009, 12:32 PM   #27
titopr06
titopr06's Avatar
Trader Rating: (68)
titopr06 is just really nicetitopr06 is just really nicetitopr06 is just really nicetitopr06 is just really nicetitopr06 is just really nicetitopr06 is just really nicetitopr06 is just really nicetitopr06 is just really nicetitopr06 is just really nicetitopr06 is just really nice
Feedback Score: 68 reviews
i dont know if this is any help but i had the same problem getting some rotors for my r33 gts-t brakes and the cheapest place i found rotors was at placeforbrakes.com for some dba slotted rotors for $283.30. i emailed every nissan store i could and none of them carry r33 rotors so you might want to look into that.
titopr06 is offline   Reply With Quote
Old 02-05-2009, 01:05 PM   #28
Z33dori
Z33dori's Avatar
ENDLESS
or
Project Mu.
yea i have planned on calling them today to price out some R32 GTR rotors, and then just shim off 1mm per side.
Old 02-05-2009, 02:26 PM   #29
Chrischeezer
Chrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the rough
got'em
Chrischeezer is offline   Reply With Quote
Old 02-05-2009, 03:15 PM   #30
Z33dori
Z33dori's Avatar
what, how does that help anything
unless u have some u wanna sell... or are u talking about teh calipers.
