Tie rod problem
So I just modded my knuckles and I don't have enough thread to correct the toe out I have on both sides.
Currently running tien s14 inners and stock s14 outer tie rods. I need either a longer inner or outer tie rod, what will work? I understand the S14 tie rods have a thread pitch of m14x1.5 so any outer with that pitch will work from nissan/inifinty? And that I can use a 99-08 maxima inner for more length? It should just screw right into the steering rack correct? |
