![]() Join Date: Oct 2002
Location: VA.. And for those that keep PMing me asking what kit I have, it's Origin Stream.
Ok, so I haven't ever really seen a decent how to on rolling or pulling fenders (if I just missed it, feel free to delete this). I learned on my car, and they came out perfect. I will also put a couple pics of my rears up at the end of this post, just for reference. It's not hard, just take a little time, and little patience. So here we go...
Rolling/Pulling fenders is done to fit wider wheels under stock fenders, as I’m sure already know before even reading this. I just wanted to start out as basic as possible. Rolling is flattening the lip on the inside against the outer part of the fender. Pulling is rolling, plus actually pulling the sheet metal out some making more room under the fender. To roll fenders, you'll need a good size hammer (like a small hand held sledge- light enough to swing comfortably, but heavy enough to actually move metal without having to beat on it all day), a couple rags (I like the red shop rags you can get at most auto parts stores, washcloths work good too. Both of these are more tightly woven than say a terry towel and don’t start shredding as fast when you’re beating on them), and a torch or heat gun. I use a torch. You need to heat the edge of the fender/lip with the torch/heat gun until the paint is hot to the touch. You need to keep the flame/gun moving back and forth from side to side. If it sits in one spot, it will scorch the paint. Keep an eye on the edge of the fender. If it starts to bubble/scorch, you either already have plenty of heat in it, or you're heating too much on the outside of the edge, and not enough on the actual fender lip. So, get some heat in it, then, with a rag wrapped around the head of the hammer, start hitting the lip upwards. You will have to readjust the rag quite often (depending on what rag you use, like I said, the red shop rags or cheap wash cloths work well). The rag will start to get threadbare where you're beating, so as you notice it wearing out, just move the hammer to another spot under the rag. So you'll work your way from the middle of the fender to one side, then back to the middle and go to the other side, then you can go back and forth, from one side to the other. Make sure to do it gradually, you don't want the front part to be completely flat, and the back part untouched or vice versa. You want the lip to be rolled in stages, from slight roll all the way across, until the lip is completely flat against the outside sheet metal. The extra rag is for your other hand, you'll need it because the fender is too hot to touch with bare hands. With your other hand, press against the outside of the fender where you're beating to keep from doing any "pulling". You will probably need to stop a couple times and reheat it, then start beating again. The heat is to keep the paint from cracking, but it also helps the metal bend easier when it’s got some heat in it. You will only need to roll from about 10 o’clock to 2 o’clock. In rear anyway, the front, you may go further, but the front is cake. The rears are harder, since they're more rigid. You will definitely want to make sure you put pressure on the outside of the front while you’re rolling, because the front’s aren’t anywhere near as rigid as the rears, so they will deform a lot easier. Just move your hand/rag along the edge, pressing inward, as you beat from one side to the other. You'll also have to remove your front plastic fender liners if you haven't already. I recommend cutting them and leaving at least a small section at the back, to keep rocks from flying up into your door. I hope this helps at least a few people. If anyone has anything CONSTRUCTIVE to add, feel free to post it or PM me and I will edit this post to add it in. Also, I don’t have experience pulling yet, but I will as soon as I get my rear 5 lug and tires for my new wheels. So if anyone wants to do a write up about pulling, I’ll put it up, but I’m planning on doing a how-to for that as well (hence the title), as soon as I get to do my rears. Here are the pics as promised. (Please no Sportmax comments, those wheels are long gone. New wheels are MUCH better...) And just for reference, the wheels in the pics are 18x8.5 +25 with 225/40/18s and 18x9.5 +25 with 245/40/18s (Falken ST-115). I was also running -3.75* of camber in the rear.
![]() Join Date: Jul 2005
Cool explanation. I felt like a kid with dislexia however, because of that big paragraph. Point form is nice.
Gj, -Matt
613DriftWerks.ca |
Deffinately a good writeup, glad to see it turned out well!!
lets see a slightly wider wheel on there with a slightly smaller tire on it for maximum wheel fitment!!! But either way it looks great!! |
I will separate it into paragraphs. It was actually a PM to someone who asked me about rolling. I didn't realize how much I had typed until I was done, and it was good info, so I just changed/added a few things.
#8 | |
A torch really helps though man. Helps with paint crackage, and also makes the metal a little softer. Heat guns work too, but I prefer the torch because I can see where I'm putting the heat. A heat gun's heat is invisible, so you can't tell how much heat you're putting where until the paint starts to scorch.
#10 | |
Hey your car looks nice!! im running the same setup, just i have a 17x9 up front with a 25mm spacer, and a 18x9.5 with a 25mm spacer in the rear. I thought it was going to be too much, but it looks nice. I had to do some what of a big pull in the rear, luckally i did not get a dent. I also did not use anything to heat up my fenders, i just pulled them, and it came out perfet lol I guess i got lucky! I also pulled the front.
If any one has any questions on a pull feel free to pm me Before (no spacer) After (dont mind the saggy bumper lol)
slide your ride.com |
![]() Join Date: May 2005
Yeah sportmax rims look ok, just a bit on the heavy side, and alot of people have them. I am getting a set to use and abuse as track rims. $400 for 4 wheels vs $400 for one, hard to beat that.
"If you rock knock-off, you are part of the problem" -myself |
not trying to discredit you or anything but wouldnt actually rolling something along the fender, instead of hammering, be safter to prevent dents on the qtre panels? and also get a more even roll?
altho i gotta admit it looks nice. nice writeup. |
FYI, S13 rear fenders like to buckle when pulling so be careful.
KILL!KILL!KILL!KILL!KILL!KILL!KILL!KILL! |
#17 |
Admin Asshole
![]() Join Date: Mar 2002
Buckling is when you pull the rear fender out and the quarter panel above the wheel well "buckles in". Look around. There are plenty of pics of this effect on Zilvia. It's almost inevitable when doing a large pull on an S13.
"Speak softly,..." -Pres. Teddy Roosevelt "Be polite, be professional, ..." -Gen. James Mattis |
#18 | |
![]() Join Date: Apr 2005
![]() ![]() ![]() ![]() Feedback Score: 6 reviews
#19 | |
![]() Join Date: Jan 2005
Trader Rating: (31)
great writeup, where in central va are u from? Right now im in Richmond at VCU
Slip Gypsies Blog Quote:
#20 | |
#21 | |
#22 | |
![]() Join Date: Oct 2003
the baseball bat method basically intails you wedging a bat (I use two different sizes on small and one thick) between the tire and the fender lip. then push down and roll the bat forward. thats it. Becareful the paint may chip or crack so using a heat gun or torch is also recommended Works pretty good but the lip is never flat the hammer method above may work a bit better if the lip needs to be really flat |
#23 | |
The tool is easy to use, you just take off the wheel and bolt it in with the lugs like you would the wheel. Then there is a nyon type roller on a lever and as you tighten the adjustment the lever pushes the roller on the inner fender harder and further...slowly you get where you need to be, nice and smooth. Kepp the heat up or you will crack the paint though, too hot and you'll burn it. |
#24 | |
Yeah, I know how they work. A good friend of mine right around the corner has one. He pulled his, and quite a few other people's with it. I'll borrow that when I'm ready to pull a little, which shouldn't be too much longer. My rear 5 lug should be on the way, my fronts got here friday. Now I just need to get on the ball and order some tires...ugh. $$$$$$$$$$$$$$$$$$$$
#25 |
![]() Join Date: Jun 2006
nice writeup. i needed this too. so basically, before i start, i need to cut off the plastic lining inside the fender?
![]() lexus baby |
#27 | |
BTW, this is only for the fronts. Rears don't have anything to take out. I have since pulled my fenders and it was not a fun job. Didn't get to take any pictures, because we had an unfortunate mishap, but I'll try to still do a small write up at some point.
#28 |
what if i dont have access to a torch or heatgun? would it be ok to do it on a hot sunny day?? or maybe hair dryer? haha
anyways, i have a dent / slight damage with a little paint cracked off my driver side front fender.. whats the best method to roll my front fenders w/out cracking any more of the paint? i feel that if i just hammer it... especially w/out heat, it will crack each time i hit it... |
#29 | |
