So I need to replace my fuel injectors but..3 of the 4 injectors are stuck and being difficult. I don't have a fuel injector puller and none of the auto stores in my area have one in stock or rent one out.
Maybe I'm trying to remove it wrong.. Any suggestions? Can someone show me a video or pictures how to remove the fuel injectors? greatly appreciate it. thanks~
FS: Nismo R-Tune Camshafts for VQ35DE. |
#3 | |
whats the proper way to relieve pressure when removing injectors? maybe i'm missing something here..
#4 | |
![]() Join Date: Dec 2003
Put the two screws back in the rail, without the cap, and use two small flat blade screw drivers to pry off of them, from the indention's on the side of the injector. They'll pop right out.
btw, is there any tool i can use to remove these injectors to make it easier? the injectors are REALLY in there. i've already cracked the plastic that holds the connector.
^there might be but that's the common removal process. You shouldn't be putting any force on the connector.
pb blast, then get a set of pliers that can grip the cap area. Needle noses are a joke. swivle back and forth for roughly 30 seconds and you should see the injector pop up out of the rail slightly. then twist and pull up, should be a 5 minute process.
0 horsepowers.· \ ' ' ·.1000 horsepowers |
#8 | |
is there a complete walk-through video or write-up with pictures somewhere? i can't seem to find a decent write-up. people just keep saying remove this, remove that...im not a mechanic so i have no idea what this or that is..and theres never any pictures. maybe i just haven't found the right one..
![]() Join Date: Apr 2007
+1 on the screwdriver method. i can have 4 injectors out and in under 5 min.
just spin the injector till the you can get leverage between the indentation on the injector and the rail, and pry up. should pop out.
#10 | |
..that amazes me. loli was f*cking around with it for a couple hours last night..manage to get one out pretty easy..just by twisting and pulling on it..didnt even use the screwdriver. all the other ones though..no go. lol looks like i got something to keep me busy on a Friday night... i'll let u guys know how it goes later..(stuck at work til 5pm..)
#11 | |
"Heres what you do. Rotate your injector so that the plug end is directly overtop of the screw holes. This gives you an extra half inch or so to pry against. There is a lip on the underside of the plug thats meant for removing the injector. Take a large flatblade screw driver, or whatever, make sure it fits under that lip. Rotate your screw driver while its completely underneath that lip by turning your wrists, forcing one edge of the 'blade' onto the fuel rail and the other end up into the injector. They pop right out dude." trust me after you do this once or twice it gets REAL easy.
#12 | |
yeah..after figuring it out the first time..i got the other ones out in less than 5 mins..lol. just used a big flat head screwdriver and popped them out. check out this picture..u can tell i had a little trouble with the first injector..loll.. ![]()
FS: Nismo R-Tune Camshafts for VQ35DE. Last edited by dkim1985; 01-24-2020 at 03:47 PM.. |
