hEY WASSUP! I GOT A QUESTIONS ON MY BELTS! I OWN A KA24E! WHENEVER I START THE CAR THE BELTS START SQUEALING! ALL BELTS ARE BRAND NEW JUST REPLACED THEM A COUPLE WEEKS AGO. I TOOK EACH BELT APART FROM THE PULLEYS ONE AT A TIME TO CHECK WHICH ONE IT WAS AND FOUND OUT IT WAS THE ONE DAT GOES TO THE ALTERNATOR. JUST 2 MAKE SURE IT WANT THE ALTERNATOR I GOT IT TESTED AND IT TURNED OUT FINE. THEN I PUT BAK THE ALTERNATOR AND TOOK THE A/C BELT AND LEFT POWER STEERING BELTS OFF! NO NOISE! COULD IT BE THE BEARINGS IN THE PULLEY THAT ARE SHOT OR WHAT? ANY ADVISE WOULD BE HELPFUL THANX! AND ALSO IF THE PULLEYS NEED REPLACEMENTS WHERE CAN I FIND SOME GOOD LIGHTWEIGHT PULLEYS! THANX AGAIN!!
