![]() Join Date: May 2010
Garage Clean out sale SR20det and KA parts
Few parts I no longer need.
S13 Shark nose bumper (white) $100 S13 Welded dif with output shafts (doubled six bolt pattern/ no ring gear) $150 KA AC condenser $50 KA AC compressor $100 SR20 AC compressor $100 S14 Tanabe Front Sway bar (gray) $100 S14 Tanabe Rear Strut bar tower $100 S13 Factory Nissan front sway bar $25 KA MAF $25 S13 OEM rear lights (no cracks) $50 Large single fan $25 Power steering reservoir $25 6lug to 5lug alum adapters (all hardware) $100 S13 OEM Manuel Driver and pass side mirrors (black) $100 Yamoto Garage RUCA (metallic purple) $100 Circuit Sports Oil/ Water temp Module with fan controller (missing one temp sensor) $100 TRUST Shift knob (scratched) $100 Greddy Profec B Turbo Timer $100 Greddy Profec B Boost Controller $100 (controller module modified/ but 100% functional) AEM Faceplate (black) BNIB Air/ Fuel $5 Fuel Pressure $5 Lambda Ratio $5 Oil Pressure $5 AEM Faceplate (white) BNIB Fuel Pressure $5 Tru Boost Faceplate (white) with gray bezel BNIB $10 AEM Gauge Bezel (BNIB) $5 Profec 4mm In line filter, Class HP (BNIB) $20 All Prices negotiable... Posted locally on Craiglist also, here is the link for images http://tampa.craigslist.org/hil/pts/5879254423.html Last edited by actiew; 12-06-2016 at 02:06 PM.. Reason: updated |
yeah that is fine but we can just meet up rather than me shipping them too you. I am in brandon and seems like from your profile you are in tampa. Price is fine with me let me know.
Injectors back up for sale, appreciate the help Flatline. Updated the post, the injectors are actually SR20 370cc injectors. Which should be a drop in upgrade for any KA or KA-T. With a minor tune may be required, so you are not running too rich.
![]() Join Date: Aug 2005
Trader Rating: (18)
Hey thanks for the ecu I left you feedback for it please do the same in return.
DON'T BE UPSET WITH THE RESULTS YOU GET FROM THE WORK YOU DIDN'T DO. |
Will be getting the additional dif welded and just adjusted the price to cover cost of welding by tech. Will get welded once time free up at the shop and provide pics of work also. Just remember it has no ring gear, but if you are doing a basic swap you can utilize your ring gear and bolt right up.
