![]() Join Date: Jan 2007
![]() ![]() Feedback Score: 9 reviews
GKTech - S13/S14/S15 K-Frame/Castor Rod Bar
The gktech K frame/castor rod bar is designed to strengthen the chassis and improve transient response by connecting the tension/castor rods. The K frame bracket reduces movement of the tension/castor rods and the lower control arms during hard cornering where handling and steering will be improved. Vehicle Compatibility: - Nissan 180sx - Nissan S13 Silvia - Nissan S14 200sx - Nissan S15 200sx Price: 69 AUD (approx. 59 USD) Shipping cost: From 36 AUD (approx. 34 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of July. ORDER HERE: http://www.gktech.com/index.php/s13-...e-bracket.html FAQ Will these fit my car? We can only confirm fitment of the vehicles listed above. If your vehicle isn't listed there then we can't be sure. Sorry How hard is the castor rod bar to install? The install is very easy and shouldn't take any longer than 20 minutes to install with basic tools. Can I use this bar with an oversized sump? Yes, your sump shouldn't sit anywhere near the castor rod bar. Can I use this bar with an aftermarket swaybar? Yes, your swaybar shouldn't sit anywhere near the castor rod bar. Can I use this bar in conjunction with your under engine bash plate? Yes, you sure can. The castor rod bar doesn't sit below the K frame so there is no issue at all. For any inquiries please e-mail us at [email protected]. |
