140k transmission oil flush?
Edit: Car is Manual Transmission, my bad
I bought the car at 124k and it seemed well taken care of and had a coolant flush and refill along with oil changes on time when I bought it. The car had no shift boot and often i'd smell a little bit of burning transmission fluid but only on hot days and when the engine was warm (fan clutch kicks in). Idk when the last transmission oil change was done but I want to do a flush. I've heard ppl say that flushing a car with high miles and not knowing when the last change was done can possibly ruin the transmission by taking out all the crap that's built up or something. Can anyone explain this to me? Maybe give me an idea on what I should do? Transmission shifts fine btw. Sometimes has a click to it but doesn't necessarily feel like a grind Last edited by NissanRWD; 07-15-2014 at 04:03 PM.. |
![]() Join Date: Dec 2012
So ur trans is auto correct?? If so, look up the " 240sx wont shift gears" my auto 240 would do it all the time. So if its running fine and u dont beat it i reccomend leaving the way it is
Yea well tht saves u a huge headache.
Well if u do decide to change the gear oil go with Redline MT-90, i gurantee 80% zilvia'ns run and reccomend this stuff. |
Dude its a manual trans, you can change oil as often as youd like to.
As far as capacity, it has a drain and fill plug. So go drive it for like 5-10 mins, then jack and stand, drain oil, then fill until the oil level reaches the fill plug. Also, its gunna be way easier to fill if you have an electric transfer pump because theres pretty much no room to pour from a bottle |
#9 | |
All the things you said are wrong and this thread is from 2014. |
