#61 |
Dude I almost ate those chocolate wafer bars sitting on your car but they were a bit melty so I put them back.
#64 |
![]() Join Date: Jan 2009
Nice things going on here!
Precision intercooler rated to 600HP Used **FOR SALE** http://cgi.ebay.com/ebaymotors/ws/eB...%3AMESELX%3AIT |
#65 |
![]() Join Date: Apr 2005
![]() ![]() ![]() ![]() Feedback Score: 6 reviews
ordered some shit. Pictures will explain. The stock fuel lines have been replaced by stainless steel lines under the car. Feed and return are -6. I chose to do this to avoid having an ugly cross over pipe in the engine bay to provide fuel. The stainless steel lines made it much easier to run the lines on the left side of the car.
#66 |
Got the manifold in
![]() Cut off wastegate flange and welded on 44mm v-band. Don't worry, its fully welded on the inside ![]() Pie cut stainless dump. Will make cool noises ![]() Threw everything on. Fitment= Dumps straight to the ground ![]() Put turbo and lines on. ![]() That is not be the filter we will be using. We just threw it on for fun. Can't wait to get the ugly ass valve covers coated. Have lots to do for it to run. The Famous Brat also makes an appearance in this pic! Big thanks to Derrick and Justin! ![]() |
#67 |
Found my camera! I want to thank Derrick Rogers for help with all this
Downpipe made. Pie cuts and flex! The right way. ![]() Pie cuts on the bottom and dump tube exit ![]() Hotpipe was super easy. Forgot to take a pic of the cold pipe ![]() Pushed the car outside to move some other cars around in the shop. Still waiting on the wiring. ![]() ![]() |
#77 |
![]() Join Date: Aug 2009
wow man mad props cat believe the shit i see done on here.. i'm in the process of my s13 but i just lost my job so you know what happens next.. hey man good luck with thsi build super excited to se it done..
RB POWA!!!!!!!!
#84 |
![]() Join Date: Oct 2004
keep it up man!!!
Drift Indy |
#89 |
![]() Join Date: Feb 2004
I took some pics of the car the other day so ill give an update of whats the haps for my good buddy here.
All the front suspension is back on Modded moog inner and outter tie rods, SPL tension arms, Derrick Rogers aka (Dmaxx) modified knuckles, and Wilwood calipers. Sexyyy angrille Also exhaust is all done and turned out badass imo, tucks up even with frame rail and looks great. Just waiting on Stance coils that should be here next week. Seriously i love the way the car sounds and it seems to spool really quick hopefully he can get it on the dyno soon with a good tune, then we can do some cool tandem, stay tooned. |
#90 |
the frame rails looks so bad in this picture. haha. You can also see the power steering cooler in this picture
What can droid do for you?? Take crappy pictures |
