![]() Join Date: Dec 2008
many things wrong. need help.
ok im going to list each problem im having and then go into more detail
first. my wipers are messing up. second. my e brake does not read that it is DIS-engaged.(tubo timer cut out does not work,) third. ive got quite a wireing clusterfuck and a plug im not sure where it goes. and fourth.i have a pump that i dont remember what it does/ where it goes so lets do it in order, wipers dont work on the adj speed, they move like odd distances, stop, move again, all with clicking from the engine bay, work fine with med and hi speed just not the timed delay.... fuse/relay blown? idk. second e brake, works on and off, havent done anything funky with the wiring for that, what can cause this? i dont want my car to drive away one day. third has pics. this part of the harness is right after the injectors before the TPS split. the car is a 91 240 with an sr N/t +t lol he used the stock harness and spliced into it. it ran before like this but i dont know what needs to be hooked up and what doesnt. just because it ran dont make it right. fourth. what pump is this? i think it pumps air? maybe a vac pump? i took the car apart like 9 months ago. i dont remember. thanks in advance guys.
grip like roots, float like leaves. wtb s13 sus. Last edited by mattro; 11-29-2009 at 08:26 PM.. |
WOW dude,you got your hands full there...
I there time delayer for the wipers ( whatever is called its under the hood ) check it as for the parking brake,there going to be button type switch,sometimes the the switch gets stuck on or w.e.
MORE BACON STRIPS
#3 | ||
![]() Join Date: Apr 2004
1. Check your Time Control Unit (TCU). Then check the wiper amp. Suspect bad fuses and/or grounds.
2. What does "works on and off" mean? Does the "BRAKE" light on the dash work correctly with the handbrake? Check that you wired the brake switch correctly. If you're sure, then the turbo timer is bad. 3. This one will be hard to diagnose even in person. Your description sounds like the car will be a handful for whomever handling the project. Expect to pay a lot of money to fix your entire engine harness. 4. Automatic Speed Control Device (ASCD) actuator. Quote:
Thank you. Please drive through. Last edited by g6civcx; 11-29-2009 at 09:38 PM.. |
1, got it ill check it.
2 yes exactly. somtimes the light on the dash works, most of the time its on. timer better not be bad, its less than a week old. 3, fukkkkk im doing it by myself. time to get out the meter. 4. so, do i need it? lol
grip like roots, float like leaves. wtb s13 sus. |
here is what ive found,
i dont need #4 its for cruse controll. that i dont have. and the brake switch, isnt that the little mechanical switch right near the base of the brake lever?
