So I had recently replaced my clutch master & slave cylinder & after I did it still had bad gear changes ruff.... So then now it got worse when I was in a stop when suddenly I heard this snap & my clutch disengaged & it launched by itself... So then I braked & it kept wanting to go by itself then it suddenly calmed down so then I tried accelerating when this noise kinda like a whining started coming up... I don't if I saw smoke coming out or I just imagined it but then I let it rest for one day & I went to my car to try to check it out, so I turned it on & with my foot on the clutch I started playing with the gears then I tried moving it when it suddenly started jerking so then I put it on neutral & tried playing with the gears & no gears would go in...
Sent from my iPhone using
Tapatalk
