VSS wiring, yes another speed sensor thread
I cannot find this info.
When you remove the speedo from cluster (4 screws) the circuit board is labeled. Ign, grnd, signal, and 2p. Which two go to the VSS? I believe it's grnd and signal. 2p goes to ecu. Is this correct? (Trying to solve a no speedo issue, tried 2 clusters. Not sure if sensor is good. It's already directly wired. Making sure it is wired correctly) Thanks
@UpshiftEngineering |
Anybody?
Msgmsgsmsg
