** Calling all the SR20DET experts...need help**
just swaped an sr20det redtop on my 240sx 91 fastback s13 with ka24de and now im missing a part
NOOB ALERT!! if u guys see the pics attached im missing the part that fits the empty socket , the other pic has the missing part installed on the socket ( got it from a my old ka24de ) and the engine started fine didnt drive it though. whats the name of the that part and if possible the part number. im just afraid the old part wont work perfectly or damage sumthin later on!! Thanks guys |
Better pictures would be nice. I think a wider shot, not so zoomed in, on the area so we can see what it may go to.
My SR20VET |
![]() Join Date: Jun 2007
I am almost finished putting my SR together after a fresh rebuild... Never seen that part before. Probably only applies to the KA. The only thing that looks even remotely like that on the SR is the TPS (throttle position sensor), but that's up front on the throttle body. What harness are you using?
![]() Join Date: Jul 2011
It's not the throttle position sensor although it looks similar. Its what I've always heard it being reffered to as an ignitor chip back when I had a gti-r swapped into my g20. It's not needed for an SR as they have coil packs instead of a distributor and coil. So get rid of it and move on. An sr fsm for your motor would help you out.
#8 | |
![]() Join Date: May 2011
