Turbo Help.
As I posted before, I'm fairly new to the turbo stuff, but I need some advice or guidance. I'm going to assume the turbo I have is bad and I want to replace it. I don't want anything too expensive since I have a child on the way, I'd never hear the end of it from my wife!
I have a 93 s13 coupe SR20DET the turbo installed is an HKS GT2835r, I don't know if it matters but the "AR" I believe is 0.80 as staked on the side? Any ideas? && thank you all so much for the help! |
#2 | |
Got that from a much older post: #/f/newreply.php?do=newreply&p=315971 So if this is in fact true then you could switch up to a GT30 series from Garrett good for about 25 PSI maybe a little more or a GT35 if you dont mind some lag. |
| help me, sr20, turbo |
