Idle Relearn on sr20det
So my car has been dead for like two weeks and when i charged it it wont hold idle unless i hold the gas pedal so how would i do an idle relearn or how would i fix this problem.
My battery dies all the time during the winter ( I was 400 miles away at school). Never had this issue nor had to do an "idle relearn" if that's even possible.
Sent from my SCH-I405 using Tapatalk 2 |
![]() Join Date: Nov 2008
When you charged the battery you probably hit the gas on accident when the key was first turned on which reset your tps closed position.
If you have datascan you can clear self learn, or you can unkook the battery over night and plug it back in the morning and without touching the gas petal start the car. This should fix you up. If that dont work your battery could be bad and throwing off the injector latency |
