accord rims on 240sx
i got a set of accord 7 spokes 4x114.3 and im trying to fit them on my 92 240sx base model
i know these rims fit becasue they have the same dimensions but when i put them on they dont fit. does anyone on here know how they fit on? ive seen these rims on a 240 before to i need help |
![]() Join Date: Jun 2002
![]() ![]() ![]() ![]() Feedback Score: 2 reviews
that is lugcentric, honda have a smaller bore than Nissans.
Nissan hub bore is 60ish honda is 50ish. if you want a honda wheel to fit, take the rims to a shop and bore out the center searchin will give you the hub bore size that is the only way i can think of having it fit, the other way is spacers. by putting hubcentric spacers to your hub and slapping the rims on, that wil make it fit |
#4 | |
if you bore it out say to 60mm and the hub of the car is 50mm. yes it will fit, but youll have to tighten the wheel carefully and make it centered, or you get hubcentric rims for about 15 bucks and it will fit back onto the accord no problem. search about hubcentric rims |
not sure about steelies, but im sure steelies dont need to be hubcentric. i have steelies from the flee market from previous owner that fit. i think steelies only need to be lugcentric. but when it comes to alloy rims then it does from the factory.
if you really want to fit accord rims onto your car and dont give a rats ass about width and offsets. buy spacers and make sure they are hubcentric to the car hub, you can have it hubcentric to the rim as well, but not really as important |
wow ditch those and get stock se alloys, direct fit similar offset and size. plus it was made for our cars.
and i never knew honda was 4x114.3 i always thought they were 4x100 |
![]() Join Date: Oct 2004
i really dont know if this will help you but I had rims on an 99 accord sedan, and those same rims fit perfectly nice on my zenki. so, the offset s the same(if i am not mistaken, and I could be; the offset is the distance of the lugnut holes to the center of the rim) but then what you will have to change is the lugnuts cuz the accord are 1.5 and the s14's are 1.25 or backwards, but check that
offsets arent the same. that has nothing to do with wheel fitment from one car to another. i guess the hub bore on the accord rims are bigger hence why it fits.
if you really want to know, go on a honda board and ask them what is the hub bore for the accord you are using the rims from. i am going based on an assumption that all honda hub bores are about 50 |
![]() Join Date: Mar 2003
earlier Accord hub bores are smaller than a 240s'. The late one's I'm not sure of 98+. My friend had a set of 93 Accord wheels on his coupe back in 95. We just took a drill and grinding stone and opened up the hub to fit. But be warned, you will be able to hide treasure in your wheel wells.
In life, we often cast the line of hope fishing for the best possible opportunity. Sometimes with enough effort, the things we catch are nothing short of amazing. |
#15 | |
![]() Join Date: Dec 2002
But it's your car, do what you want with it. Just don't post pics, some of us have weak stomaches.
civiv, del sol , crx , and integra >>4x100
prelude and accord >>4x114 but the real statement here is why the F!!uck are you going to put accord rims on your nissan, you better be desperate or a bitch one of the two |
