![]() Join Date: Nov 2010
so last night i just happen to have finished replacing the crank seal and oil pan gasket ,today i drive the car to work and back but when i got home i popped the radiator open cuz i thought i smelled antifreeze and theres foam in my radiator. it wasnt a lil bit it was like a frappuccino!!! wtf is this!! low coolant? bad water pump? btw engine is stock ka.
well i didnt mess with the radiator at all. it was fine before i changed the crank seal. i checked but nuthin. when i changed the oil pan i jacked up the engine/tranny from in between idk maybe i pinched a line??
i just checked again and i found some sort of leak in the back of the head might be antifreeze or oil leak and it seems to be falling on the tranny. could this be a bad head gasket?
![]() Join Date: Jun 2009
could be that a section of your head gasket is cracked if there's oil in your coolant or vise versa
WTB: S14 Wiper motor and S15 HLSD w/ Shafts It's always broken!
