Old 07-25-2011, 07:47 PM   #1
jad0019
jad0019 is an unknown quantity at this point
ac in sr20 swap
I was wondering how to make the KA ac compressor work in the s14 sr20det in an s14 chassis so I can use the KA ac lines. Someone said that CodyAce has the bracket for it
jad0019 is offline   Reply With Quote
Old 07-26-2011, 02:33 PM   #2
ultimateirving
ultimateirving's Avatar
ultimateirving is an unknown quantity at this point
this is correct, i bought a bracket for my s13 sr, and my s13 dohc a/c system. Just finished all the a/c stuff today and picked it up at the shop. Blows cold and everything was wired correctly.
Great Success(borat voice)
ultimateirving is offline   Reply With Quote
Old 07-15-2019, 12:10 PM   #3
Joes13Silvia
Joes13Silvia is an unknown quantity at this point
what do you mean it was wired correctly? did you have to cut or modify the loom?
Joes13Silvia is offline   Reply With Quote
Old 07-15-2019, 01:24 PM   #4
Mikester
Mikester's Avatar
Mikester is a well-known jackass
This thread is 8yrs old.
The CodyAce kit comes with everything needed (brackets, hardware, belt). The guy above just mentioned that his SR was properly wired in. If yours was, you shouldn’t need to modify your wiring or connector.
Mikester is offline   Reply With Quote
Old 07-15-2019, 02:22 PM   #5
Joes13Silvia
I appreciate the reply, I imported a silvia with a seized AC compressor and they are hard to find, so I am looking for options. it seems I just have to modify one line and everything else will bolt up with one of those kits
