Still getting speed cut
I got the broken speedo "speed cut" so i replaced it with the JDM cluster. When i rev to 6k in 3rd gear it still cuts. The new cluster works, speedo and tach. BTW, its a '90 SOHC.
Creator of the "DIY Miracle X-Brace"
![]() Join Date: Feb 2006
Holy shit..........exact same problem as me..........down to the year....
Somebody told me it might be my ECU might be in safe mode. I hate this also.........UGH! And i even cut the wire\pulled the two sensors......
IG: DARKSQUADNIGHTMARE DARK*SQUAD. SINCE 2005. |
Id suggest jus shellin out the 70 for the greddy speed cut remover, its not worth runnin in safe/limp mode or whatever your ecu might do that changes your fuel map etc.
Keep it Classy |
![]() Join Date: Aug 2005
#6 | |
Where can i get a Greddy Speed Cut Remover? I'm afraid that the CEL on the JDM cluster is in a different location as the SOHC cluster, So the CEL won't come on.... Any solutions to that? How do i get outta "safe mode"?
