I just picked up a '95 s14 not too long ago and I'm just fixing all the loose ends, so when I went to replace the bulbs behind the cluster everything seemed to go smoothly. Once I put everything back together I noticed that the cluster lights only go on once my headlights are turned off, but once the headlights are turned on the cluster lights go out. Any insight? All help is appreciated, thanks.
#4 | |
All of my interior lights function fine, it's only the gauge cluster, but using the dimmer also doesn't do anything and it's fully plugged in so Im thinking that may have gone bad as well. |
