![]() Join Date: May 2012
S12 Ka24de Swap Problem
So i've been looking through multiple forums and threads and have found many with similar problems to mine but not found an exact answer.
![]() So after doing a tune up on my s12 two weeks ago (replaced oil and fuel filter, spark plugs and wires. ran fine all week), last weekend i was out driving for around for a few hours and parked for about 5min with the car on and idling. It randomly died after 5 minutes. I replaced the cap and rotor and it started right up, but half way home it died again while i was driving. I turned it back on and drove a few more feet, but it died again after the first time. So far i checked for spark, since i can hear my fuel pump kicking on i'm assuming its working, but I'm not getting spark. I plan on checking the fuses as soon as i get a meter but from my situation does anyone think it will be a fuse or distributor? I'm also going to try starter fluid to see if it can be that once i get spark. If its neither of those I'm thinking it could be the wire harness or possibly ECU, which i hope its not. P.S. my ka24de is from a 96 s14 with s13 ignition and distributor, opposed to s14 coil packs ![]() |
#2 | |
![]() Join Date: May 2009
IDK what the issue is but FYI, the S14 KA24DE had a distributor as well.
Sounds like the coil is bad and dies when it gets hot, then starts working again when it cools off.
NismotronicSA - Speed-Density Tuning for Nissans |
#4 | |
Edit: Switch to a coil booster. Last edited by idae209; 03-18-2014 at 12:56 PM.. |
sooo I'm obviously not a professional mechanic, just an enthusiast like many of you. I had taken off some ground wires that i plugged back in when i got the car(they were taped up when i got the car so i bolted them in) because i thought maybe they were taped up for a reason by the previous owner. Car still didn't turn on, so i bolted them back up, took cap and rotor off and checked them along with spark plug wires, put everything back together then BAM! car turns on
oop: i don't know what it was but hopefully she doesn't do it again. |
| ka24de, no spark, problems, s12, swap |
