#603 |
![]() Join Date: Jan 2006
I have a couple questions for you guys.
Question 1: What kind of paint stripper is the most effective and thorough yet safe to use on aluminum wheels? Question 2: Has anybody replaced the studs on Project Kics spacers before? do you happen to remember the knurl diameter? i need get extended studs and i need to keep my spacers on the front so my wheels clear the tie rod. Thanks for the help! |
#604 | |
![]() Join Date: Oct 2007
I used this stuff when I stripped my Meisters. Mar-Hyde Tal-Strip II Aircraft Coating Remover - 3711
Blow me, bitches.
#606 |
Bandwagon.
Where can I get bilstein shocks revalved locally,
OC! |
#607 | |
usually its in the pan or just above the pan
ho ha ho chi chi |
#609 |
![]() Join Date: Oct 2005
Trader Rating: (44)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 44 reviews
Since you're somewhat local, you can check out Super Autotoyz. They have A LOT.
www.realize-jp.net |
#610 |
i have wheels i need tires for they are 17x9 +12 and 17x9.5 +12 i was wondering what size to run i was thinking 215 40 17 front and 235 40 17 in back would this be good or should i run 215 40 17 all around or another tire size
#611 |
Bandwagon.
do 215/40 all around thats what im doing.
#612 |
Hearing a weird sound under acceleration. It sounds like a skreeching noise ONLY when turning right and sometimes when driving straight. DOES NOT make the noise when turning left.
I just swapped my SR in, NOTHING is rubbing anywhere, no zipties..nothing. I thought it might have been a small leak from the downpipe but sealed it up again and its still making the noise. Someone told me that it might be possible that it might be my power steering mump going bad? IDK why only turning right and going straight though. Does the pump work hard when turning acertain direction? It isnt the manifold, not a gasket, and theres no turbo play. Its blowing my mind.
.com
#613 | |
![]() Join Date: Jan 2005
Trader Rating: (31)
so finished up my 300zx rear brake swap, got some of those adapters for the e brake cables, and got everything bolted up, Now with the ebrake handle adjustment nut for the cable all the way loosened up the e brake cables still have lots of tension on them and still are engaged. I ran the cables through the stock holes in the subframe, and they are 2+2 cables on a s13. If i don't run the adapters the lines have too much slack and if i do they are too tight. Any one have any suggestions or might have had this problem?
Slip Gypsies Blog Quote:
#616 |
![]() Join Date: May 2006
are s14 oem kouki and zenki sideskirts mounted the same way?
what i mean is the stock kouki sideskirts are mounted with screws and clips on the body of the car. are the locations of the holes and clips the same on kouki and zenki skirts? Last edited by Jakob; 02-20-2010 at 01:20 PM.. |
#620 |
![]() Join Date: Feb 2010
i was looking at getting an origin aggressive body kit. my vehicle is a 95240sx with the kouki front end conversion. do i jst order a complete 97 kit? or 97 front bumper, 95 side skirt and 95 rear bumper? im really new to this and have tried searching this. my apologies.
#621 | |
![]() Join Date: Jan 2007
You can get the whole kit. Everything else will work out just fine. Correct me if i'm wrong somebody else.. |
#623 |
![]() Join Date: Dec 2008
Trader Rating: (35)
![]() Feedback Score: 35 reviews
aight guys, after 4 LONG months of rebuilding my motor, i finally finished...got it in, wired and bolted up, fluids are in and it sits good..now it doesnt start and i cant find out why..motor turns over just fine, it seems like it doesnt get any spark, fuel does pump
what can be the issue? spark plugs/cables are fairly new, maybe a year old and they're ngk..dizzy was aligned properly with the oil pump spindle, is hooked up and grounded so again whats the issue? any suggestions? please guys im so close to driving it again i wet myslef just thinking about it oh its a SOHC ka
![]() -Jorge |
#624 |
Kouki sideskirts have I believe 5 holes on the bottom? Navan zenki sides there are two holes that mount to the front mud flap location that's already pre drilled. Also two holes in the rear. You may have to make a custom bracket unless it comes with it or drill additional holes.
#625 | |
Trader Rating: (35)
my moms car just got hit and i need this car running ASAP
![]() -Jorge |
#627 | |
I used Dow Corning silicone.
Blow me, bitches.
#628 | |
![]() Join Date: Sep 2005
![]() ![]() ![]() ![]() Feedback Score: 20 reviews
If both are good and you are cranking strong, start checking electrical. Check all the grounds. Check all the connections - make sure they are properly snapped together. On my DOHC, it would not fire but would crank hard. It turned out I didn't put together a connector correctly so it wasn't getting a signal to spark. Look it all over. If you narrow it down some more but have no luck, post your progress.
BRICKHOUSE PRODUCTS
IG @brickhouse_products |
#630 | |
Trader Rating: (35)
![]() -Jorge |
| 180sx type x kouki, 1jz, 2jz, 300zx, clutch, faq, ka24de, n/a, non-turbo, question, redtop s13 180sx silvia, s14, search, solenoid, starter, z32, zenki |
