Old 01-29-2012, 04:19 PM   #1
TurbosByTopher
TurbosByTopher is an unknown quantity at this point
Need some advice new to nissans
Im new to the Nissan game. I have build alot oh high hp Hondas and some really clean ones at that. Were selling my dads project civic and he wants to get a s14 and do a 2J swap. I just didnt know where to look at for all the info and where to get all the swap parts at. Any help would be great. Thanks alot Chris
TurbosByTopher is offline   Reply With Quote
Old 01-29-2012, 04:33 PM   #2
89JDM240sx
89JDM240sx's Avatar
89JDM240sx is an unknown quantity at this point
Call Zerolift they should be able to help you... Curious though why 2jz?
89JDM240sx is offline   Reply With Quote
Old 01-29-2012, 04:35 PM   #3
roboticnissan
roboticnissan's Avatar
Why not 2jz?
roboticnissan is offline   Reply With Quote
Old 01-29-2012, 04:41 PM   #4
89JDM240sx
89JDM240sx's Avatar
Theres nothing wrong with a 2jz at all! But most ppl go SR or Rb before 2jz not trying to be funny
Old 01-29-2012, 05:30 PM   #5
TurbosByTopher
Its alot easier to find parts for a 2JZ in the states rather then the rb
Old 01-30-2012, 01:58 AM   #6
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
have you considered the vq35? it`s a lot lighter which means you keep the good handling characteristic of the s14 chassis, can make as much power as a 2jz, motor swap kits are readily available, 6 speed transmission, and also very cheap compared to a 2jz with a 6 speed trans. just my .02 cents. good luck with your build, what ever engine you decide on.
rcdad123 is offline   Reply With Quote
Old 01-30-2012, 02:07 AM   #7
Croustibat
Croustibat is an unknown quantity at this point
Originally Posted by roboticnissan View Post
Why not 2jz?
because long, heavy as hell and quite pricey on oem and upgraded parts.
Unless you cut the firewall to mount it a couple of feet inside, it will completely mess weight distribution, and driving a nose heavy S13/S14 is not always fun.
op> Try one before doing the swap, if the new weight distribution does not bother you then do it. I think it kind of ruins the fun but that is personal taste.
Croustibat is offline   Reply With Quote
Old 01-30-2012, 05:24 AM   #8
TurbosByTopher
Whats it normally run for everything to do a vq swap?
