No Overdrive!!!
just replaced transmission and still not shifting into overdrive i have to really floor it to engage it will only engage around 75 mph and i replaced tps i unplugged rev sensor what else could it be??? need help
![]() Join Date: Jan 2012
Make sure your overdrive button is clicked.
EDIT: You UNPLUGGED the rev sensor? Why? Try replacing it, if it's not working. http://forums.nicoclub.com/automatic...e-t496584.html Or just get a 5-speed. Someone had to say it, sorry. |
Yeah I know how that goes. I've got a 5-speed in the garage and I just need the master, slave, some lines, and a clutch pedal.
Have you tried replacing the rev sensor, though? |
Bam!
SENSOR ASSY-REVOLUTION - 240SX (S13) 1989-1994 :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com Bend over, it's $133. I'm assuming you have an S13, although I don't see why it'd matter between S13s and S14s. To replace it: Quote:
