| Mid-Atlantic States DC, Delaware, Kentucky, Maryland, New Jersey, New York, Ohio, Pennsylvania, Virginia, and West Virginia. |
Can get my s14 to start.... It acts like it wants to start but doesnt turn over we have the timing to factory standards but still wont start dont no what else to do ka24de engine any ideas ??
![]() Join Date: Apr 2012
theres three problems you need to check first. for there to be fire you need oxygen, fuel, ignition. are you getting spark pull a plug wire stick a plug in it turn the car over look for spark;on all four of course. open your fuel tank filler have some one turn the car to acc, listen for a whine sound of the fuel pump, use a volt meter to check injectors. check the maf with a friends maf (if it starts and idles shitty its probably your maf but you say it doesnt start so its probably not that) hope this helps.
