#12874 | |
![]() Join Date: Jul 2009
If anything you will need wide fenders if you want big tire and no camber. But yes they will fit just tuck you engine harness and run camber as needed and since you gonna run a 215/40 i assume you should be fine with stock fender. Google does wonders. Ha. This guy if i remember has these mustang reps which are 17x10.5+27 but im pretty sure he's running spacers.
http://thatistupid.tumblr.com/ Last edited by frsh4; 12-27-2010 at 12:01 AM.. |
#12875 |
![]() Join Date: Apr 2007
The strut pictured on willtheyfit.com is almost perfect fit to S13 on Megan coilovers. 17x9.5 +12 fits, but barely. interesting.
17x10 +22 won't fit. http://www.willtheyfit.com/index.php...&Submit=Submit
#12879 |
Banned from the Marketplace
#12880 |
17x9 et0 all the way around 215/45/17 |
#12881 | |
![]() Join Date: Jan 2005
Trader Rating: (31)
needs more low oscar
Slip Gypsies Blog Quote:
#12882 |
#12886 |
![]() Join Date: Apr 2005
no need for tubs unless you want to run an angle kit. +22 will rub. you'll need to run a spacer. my friends mustangs red are 18x10 +22 and won't clear his megan tracks. he running a 225. not sure on the sidewall size. also on 20mm fenders.
#12890 |
I think he quoted an older pic (I'm not gonna check)
It wasn't as much of a rule then. EDIT: So I found the picture he quoted. It's the 6th post on the very first page of this whole thread. =| From 2007 |
#12891 |
![]() Join Date: Apr 2009
18-10.5 +15 all around 225/265 35
http://strictlycoolstuff.tumblr.com/ |
#12893 | |
#12896 |
19x10.5 +10
265/35 30mm overs -1.3 camber -3 camber
IG DearDerekKing
