![]() Join Date: Feb 2003
What are my turbo options?
ok so I NEED my car running ASAP for school/work and the motor I just picked up came with a blown turbo, and my old turbo is blown 10x worse. I need a turbo I can just buy, bolt on, and drive. I am cool with anything but another t25. I'll also be getting some 550's to go with it. I called forced performance they said turn around for the big28 is a week, that is kinda long for me cuz i need it asap, but if its that good of a turbo for its price I can wait. I also found these
How much HP do you think THIS is good for? And is it direct bolt on? Does THIS directly bolt on? Does a GT25R directly bolt on? stock lines, extension and downpipe and stuff?
WRECKED. |
Shoot you could always get the JDM Gti-R pulsar turbo. It's a T28 that will fit on the stock manifold, and you can clock it to fit the the stock downpipe placement. All of the stock lines will work, BUT you will need to custom a bracket for the wastegate, and you will need the inlet pipe cut, then rewelded to point up, instead of down. IF you have the HKS intake you don't have to reweld. The only thing is that it looks a little sloppy, and there will be intake constriction. The turbo can also be found for about $300-$6** (6 and some change) new.
Watch out for those 15mph signs.... |
