Banned from the Marketplace
i have tons of sr20 parts available.
s13 driver side axle - 40 sr20det redtop spark plug cover - 25 sr20det clutch fan - 20 sr20det coolant temp sensor harnesses - 10 apexi g shock sensor only - 20 s13 rear rotors - brand new but has rust from sitting for so long - 25 used nismo thermostat - 25 brand new autometer single gauge pod - 20 s13 timing assy relay# 2841540f00 - 10 s13 pwr window relay# 285150f00 - 10 sr20det timing chain tensioner - 20 sr20det stock fpr - 10 sr20det tps sensor - 40 greddy type r wastegate - 200 jim wolf risistors - 12 s13 aftermarket gauge bezel for dash - 10 sr20det nismo short shifter - 30 stainless steel oil line - 40 stock sr20det headstuds out of a 45k motor - 15 stock sr20det mainstuds out of a 45k motor - 15 used sr20det slave clyinder - 10 2 sr20det iacv - 40 each sr20det knock sensor with harness - 30 sr20det maf sensor with plug - 40 z32 maf sensor - 100 2 sr20det rear main seals - 25 each new oem sr20det intake and exhaust seats - 80 misc s13 realys etc. complete s13 tail lights - 100 sr20det ignitor - 40 2 sr20det intake manifolds - 30 each 1 sr20det exhaust manifold - 30 sr20det stock downpipe - 30 s13 power mirrors - 60 s13 sunvisors - 20 s13 glovebox - 20 s13 front calipers with hoses - 40 s13 stock coolant resivior - 15 2 s13 radio bezel's - 15 each 2 s13 center consoles - 25 each s13 passenger kick panel - 10 s13 rear speaker covers - 15 s13 climate control - 25 sr20det stock cams 25 sr20det stock shifter plate - 10 sr20det stock motor mount brackets - 10 sr20det stock crank pulley - 20 sr20det middle oil pan - 25 sr20det redtop block - needs cleaning - 100 sr20det ts trust manifold - 140 and theres many more. just let me know what you need and ill take a look to if i have it. Last edited by tonyssilvia; 07-02-2010 at 10:21 AM.. Reason: Update |
#19 | |
![]() Join Date: Jul 2008
more info on the block and middle oil pan
![]() Quote:
#23 |
460
2 bump limit. You can start new thread in 3 days.
