Blitz SBC-id digital boost controller, N62 MAF, S13 TPS
I have for sale a Blitz sbc-id digital boost controller complete with box and instructions. The display is in like new condition with no scratches. I am moving to a standalone that incorporates boost controller so i no longer need this.
From FRSport.com (currently costs $657): The Blitz Sequential Boost Controller i-D (SBC i-D) gives you the the power to increase and control your boost. The SBC i-D utilizes the same dual solenoid technology as the DSBC. This allows for maximum boost response up to 2.5 bar (36.75psi). This 1/2 din size is compatible with both internal actuators and external wastegates. Below are some of the key features of this unit. •Boost unit (PSI, bar, kPa, and kg/cm2) •Four different programmable boost settings •Boost gauge •Peak hold •Boost warning and limiter •Manual or automatic boost setting •Record and replay •Six different vehicle readings in digital or graph form •Data 1-3 Display - display up to 3 different electronic outputs from your ECU Note: This item is the Black SBC i-D. The SBC i-D is also available in Silver. for sale for $SOLD no cut wires, like new shape. I have real Greddy hot pipe and cold pipe with a Greddy type RS blow off valve. I will have some leftover mediocre couplers and clamps to throw in with them if desired. The Greddy intercooler I am keeping; I am having custom intercooler piping fabricated. Price is OBO; $150 shipped for both pipes and BOV, possibly with used couplers and clamps. Will take pictures upon request. OEM SR20DET spark plug cover that I don't need any more for $SOLD OEM S13 Throttle Body $35 shipped N62 Z32 MAF with plug, has one mounting hole broken off but works fine $70 2 Falken RT615 255/40/17 tires with about 35%+ for sale, $90 picked up Will trade for, or is on my 'to buy' list: NRG slim mount + quick release, newer gen Power steering oil cooler setup Shift 2.5" by 7" coilover springs, 5k and 7k SPL titanium suspension parts S14 rear subframe with minimal rust ATI super damper rear half roll cage peak performance streeet transmission mount pillar dual gauge mount enkei RPF 17x10 low offset S13 widebody parts, aftermarket front fender, side skirts in good shape, nothing too ricey Last edited by Seraphim38; 05-23-2012 at 01:22 PM.. Reason: sold updates |
