StreetRacerMotorSports Free USA Shipping
![]() Limited Time Only $112 shipped in the US AEM High Flow In-Tank Fuel Pump Features: Tested and compatible with ethanol fuels up to E100, methanol fuels up to M100 and all types of gasoline Designed for high output naturally aspirated and forced induction EFI vehicles In tank design Each pump is tested to flow 320 lph @ 43 PSI 39mm diameter fits most applications Offset inlet design eases installation Kit includes fuel pump, rubber sleeve and end caps, pre filter, hose, clamps and flying lead. $95 Shipped in the US AEM High Flow In-Tank Fuel Pump Features: Designed for high output naturally aspirated and forced induction EFI vehicles In-Tank design Tested to flow 320 lph @ 43 PSI 39mm diameter fits most applications Offset inlet design eases installation Each pump individually tested For gasoline vehicles (pump life may be diminished when used with E85 fuel) Kit includes fuel pump, rubber sleeve and end caps, pre filter, hose, clamps and flying lead Last edited by StreetRacerMotorSports; 08-30-2013 at 11:54 AM.. |
