S14 window leaking
I need help from experienced Nissan guys I just bought a 95 240sx it was raining like hell and I got wet I had notice window wasn't laying flush with trim unless pushed on top right corner of glass while shutting won't seal while pulling when sitting in car....is this a trim problem or can the window be some how adjusted? Thanks for any help that is provided
Man w/ CTSV & a Car Seat
One of the 10mm nuts holding the window to the regulator probably popped off. Open it up and inspect all the nuts holding the glass inside. While you're in there, it would be a good idea to clean the window tracks and grease the mechanism.
