I just recently added modded knuckles, stock extended LCAs with cut bump stops, Isis offset tension rods,
Isis inner/outer tierods and offset tierod spacers. Now if I'm measuring this correctly I'm only getting about 50° of angle before my leading tire tierod hits my lca. Does this sound right? My trailing tire almost hits the offset tension rod but the other tierod hits first. I'm running 17x9.5 +12 wheels up front but my suspension seems to bottom out before my tires hit anything. I could have swore people where getting more angle from just spacers, should I look into different lcas?
