![]() Join Date: Jun 2015
s14 oem parts , j30 axles, s13 bumper ,HIDs, extended studs
Got some stuff laying around the garage let me know what you need , text for pics if you want, located in 91752 ,text 6266067381
S13 5 speed driveshaft 70$ S13 coupe oem rear bumper with foam 35$ S14: Manual 5 speed ka24de dust plate 60$ Just did a 5 speed swap so i have all the automatic parts and bolts except ecu and harness and trans mount (i have transmission,dust plates, torque converter, flywheel, cooling lines, auto trans crossmember, driveshaft, dipstick , shifter asembly, shifter trim) OBO will part out peices I have an automatic oem radiator but where it connects to the cooling lines it is snapped off so it cannot be used for auto again ( comes with hoses) OBO Stock front/rear struts, spring,shocks 40$ for all 4 Clutch fan and shroud has cracks 5$ Stock tension rods 10$ Oem Cigarette lighter with 12v cover and light ring (works charges phones and devices) 30$ Oem 6 bolt axles with axle nuts and bolts to diff (driver side has a ripped boot) 40$ Stock ka intake setup without MAF 10$ Rear leather seats has rips along the top 20$ Hood latch cable with small rip but still worked fine for 2 years 10$ Window washer box and tube 5$ Stock ka spark plug wires 5$ Universal HID kit used on my s14 15$ Last edited by Zenki_Ray; 02-29-2016 at 12:13 PM.. |
| j30, ka24, s13, s14 |
