Old 06-30-2021, 11:59 AM   #1
blindside73
blindside73 is an unknown quantity at this point
looking for full electrical schematic 1996 240sx MT
I've been searching for a few days but can't find a full electrical drawing/schematic (similar to the foldout for the S13) for a 1996 manual 240sx.
I'm trying to make my own engine harness that connects to the stock trans harness and to my megasquirt ms3x (Full sequential and ignition)
blindside73 is offline   Reply With Quote
Old 06-30-2021, 01:09 PM   #2
spooled240
spooled240's Avatar
https://www.nicoclub.com/nissan-service-manuals
Old 06-30-2021, 07:26 PM   #3
blindside73
Thanks for the link, that was the first place I checked which didn't have all the pinout definitions for the following connectors.
Lower Harness src dest
E201 E17
E202 E19
E204 E18
E208 F11
Can anyone complete my tables I've started
E202/E19 Pin E202 Wire Color E19 Wire Color Notes
1 Yellow Yelllw Fused batt power to alt
2 ???
3 Red Red Speed Sensor 2
4 ???
5 White/Red White/Red Dash Cluster charging light
6 Green/White Green/White Backup light
7 Red/Yellow Red/Yellow Speed Sensor 1
8 ???
E204/E18 Pin E204 Wire Color E18 Wire Color Notes
1 White White Fused batt power to alt
E201/E17 Pin E201 Wire Color E17 Wire Color Notes
1 Yellow/Blue Yellow Blue Oil Pressure Switch
2 Black Yellow Black/White Caries starter motor signal from ignition
3 ???
E208/F11 Pin E208 Wire Color F11 Wire Color Notes
1 ???
2 ???
3 ???
4 ???
5 ???
6 ???
7 ???
8 ???
Old 07-07-2021, 08:21 PM   #4
firejackal
firejackal will become famous soon enoughfirejackal will become famous soon enoughfirejackal will become famous soon enoughfirejackal will become famous soon enoughfirejackal will become famous soon enough
The FSM sucks when it comes to the engine harness schematic.
The actual wiring diagram for the engine is not in the Electrical System (EL) document.
It is spread out to different sections in the Engine Control System (EC) document under the diagnostic section for each component. So to figure out a connector's pinout, you have to do a lot of searching and compile the information yourself.
firejackal is offline   Reply With Quote
