Old 06-26-2010, 01:49 AM   #91
babyjesus
babyjesus's Avatar
babyjesus is an unknown quantity at this point
Originally Posted by Marcus View Post
if you cant break your crank pulley nut loose:::
put the socket and a breaker bar on it, let it rest on the ground.
quickly turn key to start then off immediately. itll break that shit loose
^^dang, thats pretty damn gangsta...genious!
thelittlebigblock.blogspot.com
babyjesus is offline   Reply With Quote
Old 06-26-2010, 07:30 AM   #92
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
What about when you snap wended on bolts, like the one on, ...lets say a steering column, lol
You could weld a nut to that too. It works to remove steel studs out of anything aluminum. Now, to remove the steering column bolts in particular I just use a hammer and a chisel. If you can catch the head right you can spin the bolt loose. Then just make a little groove iin it with the chisel so you can use a flathead to run it out!
racepar1 is offline   Reply With Quote
Old 06-26-2010, 01:32 PM   #93
!Zar!
!Zar!'s Avatar
If you sprinkle some salt on your hands as you are washing them with soap, it will help clean the grease and dirt off better.
Old 06-26-2010, 09:23 PM   #94
deuce40sxftw
deuce40sxftw is an unknown quantity at this point
yeah but what about full body washed? i dont wanna throw salt over my shoulder then slip and die o.o
deuce40sxftw is offline   Reply With Quote
Old 06-26-2010, 11:09 PM   #95
maxxdsix
maxxdsix's Avatar
maxxdsix is an unknown quantity at this point
a strong face wash works wonders on grease and oil on your hands, even paint sometimes.
Only thing that was on the counter was face wash, hmmm....maybe this will work, oh shit it really works. lol
Make sure you have the right tools for the job before you start the job, even if you think you have the right tools, check to be sure before you start taking your car apart.
Always have a local friend, family member, etc. that is willing to lend you their car for a parts run if your working on your only running car, you dont wanna have to put your car back together just to get a bolt do you?
maxxdsix is offline   Reply With Quote
Old 06-26-2010, 11:18 PM   #96
dtfdanyo
dtfdanyo's Avatar
dtfdanyo is an unknown quantity at this point
sugar works too
tEAM tUCK
dtfdanyo is offline   Reply With Quote
Old 06-27-2010, 11:54 PM   #97
maxxdsix
maxxdsix's Avatar
loosen the lug nuts before you jack up the car or your gonna feel retarded when you need to ask someone in the house to put their foot on the brake lol.
Old 06-28-2010, 12:21 AM   #98
singlecamslam
What tricks do you guys use to degrease some serious shit? I'm talking about worst of the worst. What gind of grease eaters do you use? I used that purple shit, didint even make a dent in it.
singlecamslam is online now   Reply With Quote
Old 06-28-2010, 12:42 AM   #99
AN89HATCH
AN89HATCH is a well-known jackass
Gasoline works wonders
Tip if you do an oil change fill everything up etc and notice the drain plug is leaking, use a vacuum cleaner over where you fill up your oil, then you can replace the leaking drain plug gasket/bolt with out loosing any oil, even when taking the bolt out completly.
slide your ride.com
AN89HATCH is offline   Reply With Quote
Old 06-28-2010, 12:47 AM   #100
unreal-
unreal- is an unknown quantity at this point
Oven cleaner? /shrug
unreal- is offline   Reply With Quote
Old 06-28-2010, 09:26 AM   #101
!Zar!
!Zar!'s Avatar
Simple Green works wonders.
Old 06-28-2010, 09:39 AM   #102
Ceepo
Ceepo's Avatar
Ceepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enough
Super clean works wonders, i got a gallon at for like 10 bucks, it burns like a mofo if you get it on your skin though :/
TW: #/f/cars-sale/390459...d9s-coils.html
Ceepo is offline   Reply With Quote
Old 06-28-2010, 09:46 AM   #103
sirfallsalot243
sirfallsalot243 will become famous soon enoughsirfallsalot243 will become famous soon enoughsirfallsalot243 will become famous soon enoughsirfallsalot243 will become famous soon enough
Quick hand cleaning remedy to avoid walking inside-
Carb cleaner.
sirfallsalot243 is offline   Reply With Quote
Old 06-28-2010, 10:41 AM   #104
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
sugar helps coagulation(sp) of the blood on a nice cut...
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 06-28-2010, 10:42 AM   #105
sirfallsalot243
Does it burn?
Old 06-28-2010, 10:56 AM   #106
miravete
miravete's Avatar
Trader Rating: (44)
miravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant future
Feedback Score: 44 reviews
if you feel like sneezing, and you cant, look up to the sun, and youll sneeze
taking corners just as good as a drunken rhino..
miravete is offline   Reply With Quote
Old 06-28-2010, 11:00 AM   #107
miravete
miravete's Avatar
Trader Rating: (44)
if youre trying to remove the bolts that hold the air bags, and you dont have the special allen type key to remove the bolts,
use vise grips to loosen the bolts. half a turn is good enough to make it loose.
then, just use a flat head, bend the inner tip on the screw, and use the flat head to remove it.
get it? got it? good.
Old 06-28-2010, 11:24 AM   #108
dopplganger1
dopplganger1 is an unknown quantity at this point
use astro glide or other water based lubes on exhaust hangers or any hoses makes it super easy and it dries then the hoses hold really well
dopplganger1 is offline   Reply With Quote
Old 06-28-2010, 11:31 AM   #109
Souljahzs13
Souljahzs13's Avatar
Trader Rating: (66)
Souljahzs13 is an unknown quantity at this point
Feedback Score: 66 reviews
For anyone that washes the their hair with PERT Plus, that shampoo does wonders on removing any grease or oil off any part of your body. It is even gental enough for cuts and busted knuckles without burning and stinging sensations of other cleaning products.
Souljahzs13 is offline   Reply With Quote
Old 06-28-2010, 11:42 AM   #110
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Originally Posted by sirfallsalot243 View Post
Does it burn?
no...thats salt ur thinking about...
PSN
Old 06-28-2010, 11:51 AM   #111
moocowmoo
moocowmoo's Avatar
Trader Rating: (46)
moocowmoo is an unknown quantity at this point
Feedback Score: 46 reviews
Send a message via AIM to moocowmoo Send a message via Yahoo to moocowmoo
use a super concentrated concrete cleaner. the good powder shit from the janitorial supply stores.. not your normal home depot crap. Dilute it in a spray bottle as the directions say. and you should be good.
BE CAREFUL WITH THE POWDER... if you put straight powder on paint and it gets wet theres a good chance your paint will come off with it...
if not gas works.
MY TIP
If you happen to be out of carb cleaner/lube/ etc for hoses and things that wont go on. just use handsoap and water. havent had a problem yet
moocowmoo is offline   Reply With Quote
Old 06-28-2010, 11:57 AM   #112
NiSilS14
NiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond repute
I' m not sure if this has been mentioned, but when I go to install an engine into car. I'll put the motor mounts loosely on the brackets rather then keeping them on the crossmember. Makes it easier for me rather then having to try to get the bolt hole to line up with the stud on the motor mount.
For the flywheel trick i use a socket wedged between a trans bolt and the ring gear of the flywheel instead of the pry bar that was mentioned before hand.
NiSilS14 is offline   Reply With Quote
Old 06-29-2010, 03:28 AM   #113
thrasher324
thrasher324 is an unknown quantity at this point
take your exhaust off if your working on something big. cuz i dropped some bolts right into the down pipe LOL
thrasher324 is offline   Reply With Quote
Old 06-29-2010, 03:33 AM   #114
thrasher324
hahahah i do that too but it doesnt work on everyone
Old 06-29-2010, 03:58 AM   #115
michael_torres
michael_torres is an unknown quantity at this point
Speaking of hose clamps...
Better than aftermarket.
now this one of the best things to do when you have a shitty ass catback that hangs low
michael_torres is offline   Reply With Quote
Old 06-29-2010, 01:28 PM   #116
deuce40sxftw
wd40 takes off grease from hands really easily, so you dont waste expensive carb cleaner and all that good shit, plus it stings if you get carb cleaner on a cut. only downside is wd40 causes cancer, but so does motor oil and all taht other shit
Old 06-29-2010, 02:05 PM   #117
mcloud
mcloud is an unknown quantity at this point
Instead of having to worry about getting the crud off your hands... how bout never getting it on your hands in the first place? I'm talkin' about gloves of course... a good pair of nitrile gloves that fit can be a lifesaver. It sucks when you wash your hands 4 times and the shit won't come off and you've gotta go to work in couple minutes. Then the idiot in the next cubicle over asks you why your hands are so dirty. But you never liked that prick anyways.... um yea, anyways...
The catch is, they have to fit. Too small, they tear. Too big, intricate detail work becomes a pain in the ass.
Thought of another one that helped me one time. If you're like me and the Incredible Hulk put your oil filter on last oil change, one trick you can use if you don't have a oil filter wrench handy is use a belt. You just loop it through, wrap it around the filter and pull to the left. Usually works. Don't have a belt either? You can use a long screwdriver and a hammer. It's messy, but you puncture the filter all the way through with the screwdriver and voila, instant handle (and oil all over your hands and screwdriver, but you're wearing gloves now, right, and you don't care). Now turn the handle and your filter comes off.
mcloud is offline   Reply With Quote
Old 06-29-2010, 02:14 PM   #118
udon!
udon! is an unknown quantity at this point
A very small amount of muratic acid ( can be bought from pool supply store ) will remove any type of grime pretty much insantly.
udon! is offline   Reply With Quote
Old 06-29-2010, 02:39 PM   #119
joeapple8
joeapple8's Avatar
Trader Rating: (32)
joeapple8 is an unknown quantity at this point
Feedback Score: 32 reviews
Wd40+gojo=wonders
joeapple8 is offline   Reply With Quote
Old 06-29-2010, 03:55 PM   #120
trsilvias13
trsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to behold
take the handle out of the jack. use it and press the brakes, and the other end is against your seat or something. You wont need anyone to hold the brakes. Also work with a broom stick.
trsilvias13 is offline   Reply With Quote
