Power fc issues! Injectors not firing
So I have the l jetro maf version.
Also I will say my coupe has no wiring in it and the power fc/ engine harness has been hard wired It does remember previous inputs after turning off. I have a z32 maf 740 injectors Fpr S15 turbo E85 My injectors are not firing and I have no clue as to why. The harness was fine before the power fc. And all I've done is wire my start signal to a push start button, And wire my ecu and eccs powers to a switch to 12v My coil pack where not getting power either so I had wired them to a 12v and still didn't start although I had spark just no fuel Also on my signal check on my pfc is shows my EXT and WRN lights are in black. Can anyone help on the proper way to get the power fc working and receiving and sending signals? Any help would be appreciated Sent from my iPhone using Tapatalk |
