SR20DET not revving past 4.5k rpm
SOLUTION
I WIRED THE PLUG WRONG. (SR20 PLUG TO CA18 PLUG) THERE IS A RED WIRE THAT WAS WIRED WRONG. THE VOLTAGE ON IT WAS 60V FOR SOME REASON. MOVED THE WIRE WHERE IT SHOULD BE AND THE CAR FIRED UP AND I COULD REV. HOW TO FIND OUT? MEASURE THE VOLTAGE ON YOUR INJECTORS. PUT YOUR KEY IN THE ON POSITION AND MEASURE THE VOLTAGE ON THE RED WIRE(INJECTOR WIRE). MINE WAS AROUND 6V WITH STOCK ECU AND 60V (LEGIT) WITH MY POWER FC. IT WAS ALL BECUASE OF THAT ****************** WIRE So my car isn't idle. I started my car after 1,5 years with a apexi power fc D-jetro. (map sensor) Also, its a sr20det redtop from a silvia s13. The car is shaking a lot and it is between 900-1200rpm. I first thought it was running on 3 cilinders, but it isnt. all 4 of them are working. I didn't finish the self-learning process yet. I did it for almost 20 minutes. Can't go on since my car is in a public garage (which has open doors) underneath the houses and people will get mad if I do this at night. Anyway after 20 minutes there was no change at all. Things i've done:| 555cc injectors ( 66%, 0,70ms) S15 turbo Map sensor (which has a vacuum line to the throttle body, on one of the ports above) I've deleted the old map that was on it. Im gonna look for vacuum leaks tomorrow. IACV should be fine since it was running fine before, i'll check that one out tomorrow too. Any other advice that I can use tomorrow would be nice. Last edited by Shirohige; 07-10-2017 at 12:18 PM.. |
Thanks, i'll keep that in mind.
edit; I've connected the intake air temp sensor to my ECU like people said, but: The red wire(signal) is connected to a blue/yellow wire on my ECU. Anyone know if this wire is the correct one?\ EDIT; WAIT DID I FUCK UP MY INJECTOR SETUP? I put in 66% which should be good, but I see people use 0.2ms or 0.1 ms. I used 0.70ms. Please tell me this is the problem??? |
![]() Join Date: Sep 2005
What type of injectors? not all injectors have the same lag, even with the same cc. So dw555cc injectors?
Sent from my LG-H631 using Tapatalk
Edit: when i put my car on (not starting) my airtemp says 10-15 celcius, which is right. But when i start my car the airtemp says things like -8 and even -34... |
Can you lock the intake temp down in your software for troubleshooting? Disconnect etc.
Check sensor or wiring? Sent from my LG-H631 using Tapatalk
Now during the selflearning after the first 10 minutes you have to turn on the ac which I dont have. So I just turned on the fans and the car did some reallyyyyyyy weird things, watch; https://www.youtube.com/watch?v=GZXVeiSi1y0 I turned it off after that. That shouldnt be happening right? Last edited by Shirohige; 04-30-2017 at 03:23 PM.. |
Ok, i reset the ecu again and tried to do the selflearning process again. Car stayed around 600-700 rpm and engine was shaking. There was a strong gasoline smell and my o2 sensor is staying at 0.0v. How much influence does the o2 sensor have on the idle process?
I am thinking of putting my 370cc injectors in the car and see what will happen. Any advice?? I am losing hope edit; alright i might've find out about the o2 problem. here goes: The redtop uses a E63 ECU with a skinny O2, no? My redtop ran a E5 ecu with a fat O2. I think this is the problem since my power fc says the o2 has 0.0v. Also, the O2 in my car now is from a 300zx. So I might have to buy a skinny o2 sensor, but if the o2 isnt really necessarry for idle-process then i wont buy it. I have a wideband in my car (not hooked up yet) which i will be using when I'll get it tuned. Anyone who can confirm this for me? Last edited by Shirohige; 05-01-2017 at 12:20 PM.. |
![]() Join Date: May 2005
O2 sensor feedback is used during closed loop fueling, including idle.
You'll need the correct sensor that the power Fc is expecting, unless there's a way to change the o2 cal table... double check your wiring as well ![]() Sent from my iPhone using Tapatalk |
Car sat for a year and a half? Can't believe no one has said to check the easy shit first. Drain your gas tank and put in a fresh tank of gas, its probably accumulated a ton of water by now. It will still shake for a bit I imagine, but it should smooth out after 5-15 mins.
Ye I'll change the sensor. I was using a multimeter and there was no voltage on the o2 cables. Found out there was a cable broken inside and I soldered it. Still no voltage, I think the harness isn't that good anymore.
There was fresh gas in it. The gas tank was almost empty when I put it in my garage. Anyway, I checked my spark plugs again and 2 of them were completely black. When I put them in a week ago they were good, but after a few times of starting the car they were black and wet from gasoline. I ordered new ones, gonna order a skinny o2 sensor and might look for a new harness. I'll keep this thread updated. |
![]() Join Date: Jan 2012
There is a way to disable O2 feedback in the settings. It will make your car idle roughly but it's better than nothing if your O2 is stuck at 0V in closed loop.
I'm having a similar issue right now. I cleaned and tested my IACV, however I'm not sure if the coolant expansion part is working. I have no vac leaks. Before I wasn't able to get my car to start at all until I pinched the intake hose on the IACV. Now I have a surging idle. The injector latency needs to be: new injector latency - stock injector latency. So if new injectors are .77 and stock injectors are .58 then you would put .19. |
^^^hope you get your running fast
Update: I hate my life now, but hey, my car works. After 400+$ further I found some issues. O2 didnt have a 12v output since the brown wire from the plug wasn't connected at all. I ordered a new engine harness, spark plugs and some other small stuff. Had to swap the plugs and everything. Car started, not idle. I didn't want to check my IACV yet so I thought; I'll check my injectors first. Took them out, they were under gasoline. Both O-rings on 2 injectors. Switched them with my stock ones and the car worked perfectttttttttt. Well it idles perfect at least. I thought I would go for a small drive, tested my brake and it was full with air, rip. So I thought, lets rev this b*tch up a bit since I missed the damn thing. Started revving, not above 2k rpm. When I hit 2000rpm the EAI sensor will turn on on the handcommander. Should be something with the emissions right? |
update; So i tried running it without my TPS (which is automatic, my car is manual, i re-wired everything to make it work so thats not the problem). Anyway, idle with tps is around 870-900 rpm. Idle without TPS is around 1000-1100rpm, car still didnt rev past 2000rpm.
I used some carb cleaner on my Coldpipe and everything on that side of the engine, nothing weird happened, no leaks. Thought it was my map sensor so I used a T off the FPR but that wasn't the problem either. Saw a little coolant leak on the waterpump but nothing crazy, just a few drops. The TPS is at 0.44v which should be good, but WOT it only goes to 0,56v? When the car is just "on" and I put my foot to see what voltage WOT will give it will go to 4.4 or something. But when starting the car it just won't get past 0,56v and it looks like the PFC just cuts the fuel for the engine. I still don't know what the EAI sensor stands for? Should I just do the self learning process again? Can it be because of a faulty turbo or something? Currently running: map sensor, stock injectors, gt28 s15 turbo edit; ok after some intense FBI kinda research I found out that it isnt the EAI. I might look for a manual TPS and try that, not sure if I will. Might try my old ecu tomorrow and see what will happen. Last edited by Shirohige; 05-17-2017 at 01:16 PM.. |
Problem found; I tried doing the self-learn process, didn't work. TPS was fine, MAP sensor was fine, IAT was fine, ecu was fine, all wires were fine, wastegate was fine, no boost leaks. The goddamn problem was a tiny bit of air in my cooling system. The tiny bit came out and the car could suddenly rev to the max.
Hope this will help someone in the future. |
Alright it actually didn't work a day after it worked... I have been messing with some things since then. This is what I did, and here is the solution (solution to not revving past 2k)
Changed TPS Changed waterpump (leaking) Changed radiator (leaking) Changed thermostat (no hot air) Changed engine harness (faulty wires, broken wires) Been messing ever since. Today someone told me to put the MAP sensor vacuum line on the T of the FPR. After that I resetted my power fc and it initialized again. After that it suddenly worked. If you ever face the same shit, try putting your MAP vacuum line on your FPR. Good luck, hope it still works tomorrow. |
#17 |
Alrght, it didn't work. Can't go past 4.5k rpm now. Injectors go on 0.0% when it will reach 4.5k (around 4.5k atleast).
Anything I can try? Gonna look for leaky injectors tomorrow |
The first thing we should talk about is the engine’s idle circuit. I'm going to cover a fuel-injected engine here. Carbureted engine idle problems are handled differently. Since there are so many different configurations used depending on make and model, I'm only going to speak in general terms.
One of the prime suspects here is the idle air control valve, or IAC. This is an electronic motor that varies an opening in the intake that allows air to bypass the throttle plate when it's closed. The amount of air needed to maintain your idle is calculated by the computer. The computer dictates an IAC positioning based on inputs from the engine’s sensors, usually: CRANKSHAFT SENSOR Coolant temp RPM Air temp MAP sensor readings BARO sensor readings O2 sensor readings when in closed loop Air fuel sensors or AF sensors (similar to O2 sensors but a little fancier) MAF sensors if equipped TPS sensor Load sensors such as the type for power steering pressure AC clutch activation Those are just the ones I can think of off the top of my head. I have a reason for listing all of these sensors. If you have a check engine light on for any for the above sensors, repair that fault first, then recheck for your idle problem. I've had many people come to me and say that they've cleaned their IAC valve and still have an idle problem. Personally, I haven't had much luck cleaning IAC valves. I recommend replacement instead of cleaning if you find yours to be bad. I'm not saying don't clean them, because you might just get lucky, but if cleaning doesn't work, then you might end up having to replace it. |
#19 | |
But only problem now is not revving past 5k. When I have to start my car i have to crank like 7 times for 10 seconds before it will actually start. Apexi Power FC gives a Starter error so im gonna check all my ground cables again |
#20 | |
![]() Join Date: Jun 2007
What would you like it changed to?
#24 | |
![]() Join Date: Mar 2011
#25 | |
. But someone on the forum said that you can check leaky injectors when you turn your key in the ON position? Might do that.@S-Nation S13 Alright, im gonna do a bit of research on that, thanks. |
#27 |
![]() Join Date: Jan 2008
Trader Rating: (92)
![]() ![]() ![]() ![]() Feedback Score: 92 reviews
to check for leaky or busted o-rings on injectors i usually just pull the spark plugs out before i crank the car. Ill let the car sit over night, and then pull the plugs in the morning. smell the spark plug. we all know how gasoline smells like.
#28 |
Didnt have much time to do stuff because my exams.. Anyway here is the car doing weird while idle.
https://www.youtube.com/watch?v=7FiQ...ature=youtu.be What u guys think? Leak? |
#30 |
Alright, did a boostleak test today. No leaks. Still not revving past 4/4.5k. The starting problem is most likely because of the orange wire. It fired up right away 2 days ago when it was pretty hot.
Haven't done anything to the orange wire since that is not my main problem now. Wanna get this car fixed already. Any ideas what it can be? Could it be a faulty power fc? I just dont wan't to think about the powerfc being faulty. Costs me so much money lol |
