Old 03-19-2011, 09:32 AM   #1
gian52
gian52 is an unknown quantity at this point
3rd battery in one mounth !!!!!!!!!!!! HELP !!!
ive replaced my battery 3 times this month. i took the alternator out took it to pep boys it charges just fine. ran brand new grounds when i got the 2nd battery. alternator grounds are good also. checked all my fuses they are fine. wth can be draining my battery ?!?!
gian52 is offline   Reply With Quote
Old 03-19-2011, 08:54 PM   #2
rollout240
rollout240's Avatar
Trader Rating: (31)
rollout240 is an unknown quantity at this point
Feedback Score: 31 reviews
Send a message via AIM to rollout240
could be something as simple as a dome light that stays on or lights.
"Take it to the Dome!!"
http://rollout240.blogspot.com/
rollout240 is offline   Reply With Quote
Old 03-19-2011, 09:02 PM   #3
MisawaJason
MisawaJason's Avatar
MisawaJason is an unknown quantity at this point
yeah, you've got some kind of parasitic draw going on
1 year tour in Korea = no car. FML.
MisawaJason is offline   Reply With Quote
Old 03-20-2011, 02:42 AM   #4
lenox_240
lenox_240's Avatar
lenox_240 is an unknown quantity at this point
^^^ agree, i will say the same. gl with the problem man let us know if u are able to find a solution.
lenox_240 is offline   Reply With Quote
Old 03-20-2011, 02:52 AM   #5
cordobes
cordobes is an unknown quantity at this point
check for the hatch ligth if turn off.. also..i did say take the car to advance auto parts and tell them to check ur batery and alternator again ( without removing the alternator )
or if you want try this.. get new batery.use the car but everytime u shut off ur car. disconnect the battery !if u do that and ur car eat that batery too ..ur alternator is not charging good no matter what! just try that for a few days to see if is a ligth or something else eating ur batery .
cordobes is offline   Reply With Quote
Old 03-20-2011, 03:10 AM   #6
negrosx13
negrosx13's Avatar
negrosx13 is an unknown quantity at this point
Send a message via AIM to negrosx13
my friend is having the same problem,he has killed like 8batterys already..I found out that the alternator is shorting out..it still charges but kinda low( 13.3v-13.4v ). In fact the alternator power wire almost burn my volt meter lead..lol
MORE BACON STRIPS
negrosx13 is offline   Reply With Quote
Old 03-20-2011, 09:09 AM   #7
gian52
i dont think its a parasite because the car turned off on my while i was driving. when i floored the car it started to sputter then it bogged up then my headlights turned off then my gauges then it was just a real bad idle then it jus turned off. i jump started it then it drove for like 5 mins super shitty then it jus killed my battery
Old 03-20-2011, 09:10 AM   #8
MisawaJason
alternator
Old 03-20-2011, 09:14 AM   #9
babillaracing
babillaracing is an unknown quantity at this point
take it to a good electromechanic
618 whp tuned by alpha
babillaracing is offline   Reply With Quote
Old 03-20-2011, 11:16 AM   #10
jacobs13
jacobs13's Avatar
jacobs13 is an unknown quantity at this point
you can check parasitic drain by removing the negative battery terminal when the car is off and putting a multimeter on the neg. terminal and the other lead on the actual ground cable. Set your meter to amps and see how many its pulling over time. It takes about a half hour
jacobs13 is offline   Reply With Quote
Old 03-20-2011, 07:46 PM   #11
yabeet
yabeet's Avatar
yabeet is an unknown quantity at this point
Or just do a draw test w a multimeter first, Jesus Christ.
The thing is, it’s a gearbox, okay? It has one job to do! One job! Pull the lever… ‘Am I a pencil? Am I a cauliflower? Am I a nuclear power sta– I’m a gearbox! Oh, heavens, I’m gonna swap some cogs around!’
Jeremy Clarkson on Automatics
yabeet is offline   Reply With Quote
Old 03-20-2011, 09:11 PM   #12
repda916
repda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymore
orrr with a test light, disconnect the positive terminal and put the test light on the battery terminal and one on the positive wire to make one circuit/ the light should be on if you have something draining it. pull every fuse one by one till the light turns off. when you have found that fuse go back and trace everything that fuse is used for. easy.
repda916 is offline   Reply With Quote
Old 03-20-2011, 09:13 PM   #13
jesse_s13
jesse_s13's Avatar
jesse_s13 is an unknown quantity at this point
diooooodddddeeeesss??
jesse_s13 is offline   Reply With Quote
Old 03-23-2011, 12:14 AM   #14
ellococt
ellococt is an unknown quantity at this point
Send a message via AIM to ellococt
^^^ Bad diodes can also allow current to leak from the battery back through the alternator to ground, causing the battery to rundown overnight.
Signature Deleted
ellococt is offline   Reply With Quote
Old 03-24-2011, 04:47 PM   #15
gian52
alt fuse good. i checked all the wires on the alt they came out fine. so i changed the alternator and got ANOTHER battery and turned on the car super duper shitty idle i turn on the ac and headlights the car almost turned off on me. wtf is happening.
Old 03-24-2011, 04:48 PM   #16
gian52
wut is a diode ?
Old 04-14-2011, 09:40 PM   #17
s13jojeda426
s13jojeda426 is an unknown quantity at this point
So what did you do, just replace the alternator?
s13jojeda426 is offline   Reply With Quote
Old 04-15-2011, 09:16 AM   #18
Chaluska
Chaluska is an unknown quantity at this point
Originally Posted by gian52 View Post
wut is a diode ?
Chaluska is offline   Reply With Quote
Old 04-16-2011, 02:17 PM   #19
Mishkin_707
Mishkin_707's Avatar
Mishkin_707 is an unknown quantity at this point
Check your aftermarket electronics, stereo, alarms, iPod docks, lighting anything you've added
Mishkin_707 is offline   Reply With Quote
