where do these wires go?
just swapped my fuse box and i need to kno where do these 2 plugs go? does not seem like there is anything else there for them to plug in to.
Uploaded with ImageShack.us |
yeah its an s14 with an s14 SR20DET, and when i swapped everything out i went in reverse order to put it back together and i cant find this on the other fuse box. i also had a freind helping me and at first he cut some stuff like a retard lol
Auto to manual swap? If so, you aren't going to have one of those plugs. They are for the lower harness. The white one looks like it plugs into the connector at the battery, however the triangle one is definitely for the lower harness.
My SR20VET |
{Bumping due to me finialy having the funds to finish my project dont what anything to hold me up}
i am going to jump the white wire off a matching one in the fuse box, now does any on have any idea where the other one goes? or should i just do the same thing? |
