![]() Join Date: Aug 2012
Low car problems
So my rear toe rods are hitting my subframe. Anyone had this same issue when going really low? If so, how did you fix it? I have powered by max subframe risers and they still hit.
![]() Join Date: Mar 2009
You contradicted youself when drop knuckles cost way more than some bent toe arms.
I'm sure that car has a ton of travel available too. Looks like you can even see a mark where the arm hits the subframe stud. |
