![]() Join Date: Jun 2002
P2M New Item Release: Nissan RB25/26 Water Pump
OE replacement water pump for all Nissan RB25/26 Engine. This water pump was modified to accommodate both bolt hole pattern for RB25 and RB26 engine. Comes brand new with gasket and fan clutch studs. Available in stock now! $58.50 w/free ground shipping.
![]() 909-594-3619 Business Hours: Mon-Fri 10am-6pm (Pacific) email: [email protected] http://www.phase2motortrend.com |
You can proceed order directly from our website:
http://www.phase2motortrend.com/prod...a-21u26-nk.htm Thanks! Sent from my D6653 using Tapatalk
Yes that is what we are working on next =)
#8 | |
Techincally the N1 pump doesn't flow more, it pumps harder. ![]() In our opinion the water pump plays just one role in the efficiency of the cooling system. Putting water pump aside (provided that it's in working condition), we put bigger attention to the lower deg thermostat, higher volume radiator and good CFM electric fan to achieve proper cooling of the engine. Water pump itself N1 or not will not do the job by itself to lower the engine temp.
