How much/where to buy vac line for VG30E?
I've got a VG30E that I want to replace all of the vacuum lines on. How much should I buy, and where's a good source? I found a site that sells a generic kit, but it's $70 after shipping so I'm not sure if that's the best route.
Thanks in advance. |
Use fuel lines, they hold better than anything.
Go to a hardware store farmers use. they hold the best temperatures of any I've been through. If not I've had success with colorful engine bays through conceptua tuning on e-bay. Good quality in whatever color you want ![]() Search query included in URL below. http://www.ebay.co.uk/sch/i.html?_od...icone&_sacat=0 same price as you found, they hold pretty well, but my experience is that you cannot fail with fuel lines for it (general car fuel lines) that also can take ethanol. both options that last well, last option looks very stockish too ![]()
OakHeart Racing |
The problem with fuel lines, since they tend to be rated for a higher pressure and higher insulated temperature, they also tend to be more expensive due to this very reason.
I agree however, use fuel if you can ![]() |
