#61 |
![]() Join Date: Oct 2006
weight reduction, weight reduction, weight reduction.
gut that beast, hole saw/ swiss cheese every internal panel that won't let rain in and call it a day!! |
#62 | |
![]() Join Date: Dec 2008
#63 |
This is a really nice build love the suspension swap and the new power plant is way more wallet friendly in the end.
http://www.facebook.com/BaddlineCust...lision?fref=ts |
#64 | |
![]() Join Date: Mar 2009
Worth every penny. The one front tire has some mild curb rash but is perfectly fine. Tires are still pretty good. and yes this powerplant will pay for itself in the long run, parts and stuff are a lot cheaper, and Its easier to work on if I NEED to do something to it. I'm going to try to keep this car a long as possible.
#65 |
I gotta get the spindles for the 5 speed swap but if I can get them for a decent price I am down. And if you ever need any engine stuff I have 4 spare ka's lol.
#73 |
When I saw the title I wanted to call you an idiot.
When I saw the car I wanted to high five you. This thing is cool. Bring it to clubloose. |
#77 |
Metal headgaskets, metal intake and exhaust gaskets, modifying exhaust, lowering it more, custom lca's, spl tie rods, pbm subframe risers, spec stage 2 clutch, new fenders, custom paint job, oem front bumper, did i mention lower it more?
#78 |
ur SO scared...you wont lower it more! jk.... sweet build man. tastefully done.
S14-vlsd/coilovers. L33 swap, ENGAGE! www.arnaturalselection.blogspot.com |
#80 |
![]() Join Date: Jan 2005
any way around the custom oilpan sump?
also if your much in the Christmas spirit wanna pm me the details of wiring for this swap? ill put a bumpersticker with your name on it on my Z..... |
#81 |
![]() Join Date: May 2009
![]() Feedback Score: 20 reviews
nah there isint any way around the custom sump with ka into a z32
on another note if your doing a VG into a 240 you just need a j30 oil pan and sump. and the wireing is pretty simple, use a KA ecu and a KA harness. all you gotta do it look at the pinout and make sure all the 12 volts are correct (switched and non switched) make sure all the gorunds are correct and wire in the tach and IGN. then troubleshoot. and thats prety much it. the 90's era nissan ecu's are quite simple to transplant. I.E sr20 into a honda delsol. wireing only look like 2 hrs, cake mode. you just need a pinout for the ecu and a full wireing diagram for the Z and the 240 and the VG, a good logic probe and a vold meter. just do some line follwing and its not to hard. |
#83 | |
![]() Join Date: Sep 2007
Trader Rating: (25)
How about this, why not?
![]() Awesome swap, Mike. I didn't think you'd actually go through with it since you're always changing your mind, haha.
#84 | |
@tant - yes, theres no way around the custom oil pan, the sump sits directly on the crossmember with the motor mounts i made. with the vg, even with a j30 oil pan(which i have) you still need to modify it some to clear the crossmember correctly. and I will be using a vg30 harness and just modifying it to work on a 240, because theres an igniter and coil packs, making a 240 harness work would be pointless. @rhs - yeah, I know i change my mind a lot, I want everything, but you can't have everything, so i change my setups often, but my 240 is the last chassis i'll own for drifting for a long time, and i'll be keeping the vg30 in there for a long time, as for this z, I don't know whats going to happen to it. if i keep it its getting my 18x10/18x11 wheels and a fresh paint job, if i don't keep it, i'm getting a 350z, that's the only car i'd switch too.
#85 |
Okays, heres the update.
I have my wheels, not installed yet but shortly(18x10s). I purchased an act stage 3 unsprung clutch. shortly ordering my headgasket so i can install my built ka head. Once all that's done and installed, i'm sending my knuckles and lcas to powered by max for some hardcore modifications, to have a z with the most angle ever ever. and ordering they're coilovers hopefully. Then its going for paint and getting new fenders and an oem front bumper then getting it retuned so its more reliable. the end. pictures soon. just wanted to give everyone a heads up
#86 | |
![]() Join Date: Nov 2009
Trader Rating: (42)
![]() Feedback Score: 42 reviews
SW Fab |
