Old 12-22-2008, 08:35 AM   #1
sausage180
sausage180's Avatar
sausage180 has a spectacular aura aboutsausage180 has a spectacular aura aboutsausage180 has a spectacular aura aboutsausage180 has a spectacular aura aboutsausage180 has a spectacular aura aboutsausage180 has a spectacular aura about
KA Clutch Bolt
i was working on my flywheel and clutch for some time yesterday and was wondering when i had to torque the bolts back in at 20 pds, one of the bolts broke in half. i was wondering if anyone has had this problem before and if it'll be fine for me to drive around with. thanks
sausage180 is offline   Reply With Quote
Old 12-22-2008, 09:18 AM   #2
projectRDM
projectRDM's Avatar
Pressure plate to flywheel bolt? It won't hurt anything to have a bolt missing but I'd try and remove the damaged portion and replace if you can. You don't want it backing out and becoming loose within the bellhousing.
FORMERLY R240NA
Old 12-22-2008, 01:45 PM   #3
s14unimog
s14unimog's Avatar
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Send a message via AIM to s14unimog
how did you break a bolt with only 20lbs of force.... somebodies lying
I agree with Russ, if you leave it, its likely to work its way out and get loose.
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 12-29-2008, 11:59 PM   #4
schmauster
schmauster is an unknown quantity at this point
Im hoping he means a pressure plate to flywheel bolt.. those go to about 15-20 ftlbs and they like to strip.... dont even think about driving around with a pressure plate bolt missing haha
schmauster is offline   Reply With Quote
